BairleaFarm 344 #1 Posted April 30, 2008 Kinda hard to search for the term "wheel" it seems to be used all the time on this site What is the bolt pattern on the rear of my tractor? will all the wheel horse or other garden tractors interchange? I know the height and width may be different but the bolt pattern is all im really wanting to know. Share this post Link to post Share on other sites
nylyon-(Admin) 8,813 #2 Posted April 30, 2008 I don't know the exact bolt pattern, but it is pretty standard. What isn't standard however is the offset. Most any C-Series, 300, 400, 500 series wheel will fit your tractor and should be easy to find. A JD wheel may fit the bolt pattern as well, but the offset may be incorrect, something to watch out for. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #3 Posted April 30, 2008 The " common majority" of the 5 lug bolt patterns have a 4.5" diameter "circle". (including yours) If your tractor is they way I remember them, it has longer axle shafts than a garden tractor with the 12" rear wheels. This was done because the 8 and 10 inch rear wheels were about a 50/50 offset. If you install "full offset" 12" wheels (about 2" backspacing) on your tractor, half (or more) of the tire will stick out from under the fender. :whistle: Share this post Link to post Share on other sites
CHARGER9AUTO 3 #4 Posted April 30, 2008 Kinda hard to search for the term "wheel" it seems to be used all the time on this site What is the bolt pattern on the rear of my tractor? will all the wheel horse or other garden tractors interchange? I know the height and width may be different but the bolt pattern is all im really wanting to know. I have the same tractor like in your avator '73 8 HP 4-Speed on the rear bolt pattern takes the 3/4" larger Lug Bolts to keep the 20x8.00-10 rear wheels on the hubs . Ben :WRS: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #5 Posted April 30, 2008 the rear bolt pattern takes the 3/4" larger Lug Bolts to keep the 20x8.00-10 rear wheels on the hubs . Ben The hubs are still drilled & tapped 7/16"- 20 though. You can use a "standard" wheel bolt with a 5/8" hex to install 12" wheels on those hubs. (the 3/4" hex bolts will also work) Share this post Link to post Share on other sites
BairleaFarm 344 #6 Posted April 30, 2008 I dont suppose that bolt pattern is the same as a chevy 5 lug or other auto is it? Thanks for all the answers guys Share this post Link to post Share on other sites
Kelly 1,037 #7 Posted April 30, 2008 Same as small Ford car or Ranger pickup and some Chy. and AMC's Share this post Link to post Share on other sites
KyBlue 655 #8 Posted May 1, 2008 Should be the same as a Ranger or S10. I know the Ranger is a 5x4.5 I think the S10 was too. Also some trailer rims are that size. Share this post Link to post Share on other sites
Kelly 1,037 #9 Posted May 1, 2008 S-10's are not right and will not fit Share this post Link to post Share on other sites
CHARGER9AUTO 3 #10 Posted May 1, 2008 Kinda hard to search for the term "wheel" it seems to be used all the time on this site What is the bolt pattern on the rear of my tractor? will all the wheel horse or other garden tractors interchange? I know the height and width may be different but the bolt pattern is all im really wanting to know. This my '73 8 - 4 SPEED I picked up at the '06 Wheel Horse show in PA I put new 15x6.00-6 front tires with rims I'd ordered from NORTHERN HYDRAULICS replaced the old decals with new ones it runs like a Champ . I refinished the foot rests with KRYLON BANNER RED spray paint . Ben Share this post Link to post Share on other sites
KyBlue 655 #11 Posted May 3, 2008 Okay Kelly, I stand corrected then, I was thinking that the S10s used the small pattern. I got an excuse thou, I aint a chevy guy! haha Share this post Link to post Share on other sites
