Zeek 2,298 #1 Posted December 10, 2010 I'm looking at an 855 and the owner tells me that while driving around the transmission hesitates at times. He says he not familiar with WH and doesn't know if it's "minor or major". Any ideas It's running for $200. Thanks! Share this post Link to post Share on other sites
Rollerman 290 #2 Posted December 10, 2010 It could be as simple as an old worn out drive belt or tension spring. Also check the key ways in the transmission drive pulley & the wheel hubs. 855's are pretty simple machines & one of my favorites. There not much that could go wrong in the trans case that can't be fixed with a little work. Good luck...if it's straight & running I'd probably jump at it. Share this post Link to post Share on other sites
Zeek 2,298 #3 Posted December 10, 2010 I suspected that, but am not familiar with that model. Thanks! Share this post Link to post Share on other sites
Kelly 1,035 #4 Posted December 10, 2010 Even if it needs a Trans, but I doubt it, it's worth $200 if in good shape, but I'd offer less, you never know. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #5 Posted December 10, 2010 Is it the one in Hartleton? :ychain: Share this post Link to post Share on other sites
Zeek 2,298 #6 Posted December 10, 2010 Is it the one in Hartleton? You first :D Share this post Link to post Share on other sites
WheelHorse_of_course 100 #7 Posted December 14, 2010 All of the Hydro Horses I have used (e.g. all Sundstrands) have what I would describe as "lots of hysteresis" in the drive. What I mean by this is that if you go down a hill, at the bottom of the hill the tractor will slow way down and then, about a second later, catch up and get back to the speed you were going. If this is what the owner is describing I would call it "normal" though since I have never driven a brand new unit so maybe it is just "common". Not a nice thing, but fairly harmless, and you do get used to it. :ychain: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #8 Posted December 14, 2010 An 855 is a 3 speed gear-drive, Rolf. :ychain: Share this post Link to post Share on other sites
WheelHorse_of_course 100 #9 Posted December 15, 2010 An 855 is a 3 speed gear-drive, Rolf. d'oh! I read "hesitates" and immediately thought hydro :D Share this post Link to post Share on other sites
