CTPATRIOT 12 #1 Posted December 6, 2010 How do i tell if mine is an "A" or not?Wondering where it would be marked?Thanks Share this post Link to post Share on other sites
Kelly 1,037 #2 Posted December 6, 2010 I don't believe they are marked you just have to be a detective and figure it out a 1054 is a 1964 the 1054A is a 1965 Share this post Link to post Share on other sites
Sparky-(Admin) 24,632 #3 Posted December 6, 2010 If you have the original motor the spec # is differant. The 1964-1054 is a K241-s 46215A 10. The 1965 1054A would have a K241-s 47176 10. The tranny are actually different #'s as well but I have no idea what the diff is. Probably something inside that we cant see. Mike............. Share this post Link to post Share on other sites
Indy w h 5 #4 Posted December 6, 2010 Also you can look at the serial # (but I can't remember what the # is) Indy Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #5 Posted December 6, 2010 If you have the original motor the spec # is different. The 1964-1054 is a K241-s 46215A 10. The 1965 1054A would have a K241-s 47176 10. The tranny are actually different #'s as well but I have no idea what the diff is. Probably something inside that we cant see. Mike............. Product service bulletin 71 shows the 1054 and 1054A using the same K241S-46215A engine. A later PSB # 301E shows the 1054A using a K241S-47176 and looks like this is where Toro got their info. The 47176 is a spec number for a K301. If you follow the transmission model numbers they all changed for 1965. That is also when the revised shift rails and stop pin was introduced so suspect that is what created the new model numbers. The operator manual for the 1054A shows the same 5047 transmission as used in the 1054. I think by the time they started to produce the tractors they had the 5051 with new shift rails. The shift rail PSB is # 60 and the part numbers never changed so can't trace them that way. Garry Share this post Link to post Share on other sites
CTPATRIOT 12 #6 Posted December 6, 2010 Thanks guys,it has the older spec #.Also,does anybody know the engine oil capacity? Share this post Link to post Share on other sites
Lane Ranger 11,797 #7 Posted December 6, 2010 One other difference to note. The wider front tires (which of course can be changed on a tractor) was the one noticeable difference on a 1054'A. They has tires like that were 16X8x8's I believe like the 1970's models B-100 and B-80's. :ychain: Share this post Link to post Share on other sites
CTPATRIOT 12 #8 Posted December 6, 2010 Mine has the narrow fronts also,safe to say it's a "64 i think. Share this post Link to post Share on other sites
