mdmranger 0 #1 Posted December 3, 2010 Hi, I have just installed my snowblower onto my D160 and found that the drive was not turning fully, After close inspection I found that the driveshaft is pushed all the way back up against the knuckle on the end to the gearbox preventing it from making a full turn. Got the gear box off but can not get the driveshaft to slide, tried to use a little help with a hammer then soaked it in penetrating oil over night, still no luck. Any suggestions out there? Share this post Link to post Share on other sites
AMC RULES 37,251 #2 Posted December 3, 2010 Might take a little while to penetrate in there, keep trying. You're on the right track. In the mean time try a bigger hammer? Just kidding. Share this post Link to post Share on other sites
Operator 7 #3 Posted December 3, 2010 Just in case there is one on the E-Bay right now, $30.00. I think I can mention it? Randy Share this post Link to post Share on other sites
.5racer 15 #4 Posted December 4, 2010 Being a Machinist and Welder for a looooooong time dealing with such things .. Dont laugh ,heat with a small propane torch . The same kind used for sweat soldering. Melt a little WAX (doesn't matter what kind crayon ,candle,birthday works good ) . Let cool for the wax to set up AND wala ,it slides off . Works the same for stuck bolts . Just try to remember that wax gets real runny and get into everything . The real trick is to let it COOL back to wax so it works right !!!! Share this post Link to post Share on other sites
bitten 134 #5 Posted December 4, 2010 I wounder if the wax trick would work on a stuck hub Might just have to try it. Share this post Link to post Share on other sites
.5racer 15 #6 Posted December 4, 2010 Worked on a rusted bearing on a rusty shaft,and slid right over rust right off shaft. Just get hot enough to melt wax down deep enough,than COOL !!!! cooling is the real trick. Share this post Link to post Share on other sites
mdmranger 0 #7 Posted December 7, 2010 Heat did the trick, thanks for the help, Share this post Link to post Share on other sites
