tarcoleo 119 #1 Posted November 28, 2010 Has anyone repaired steel mower decks with fiberglass patches of any sort? I'm thinking of repairs resulting from corrosion in areas where the structural integrity of the unit is not an issue. In other words, just to close holes. If so, what are the products or procedures that would do the job, please. Tom in RI :thumbs: Share this post Link to post Share on other sites
Forest Road 594 #2 Posted November 28, 2010 Probably not a good idea. I wouldn't suggest walking through that lawn barefoot. Share this post Link to post Share on other sites
wallfish 16,036 #3 Posted November 28, 2010 I haven't done it but I have decks that are repaired with fiberglass patches that seem to have held up pretty good. Welding in patches of steel would be better but small fiberglass patches shouldn't be a problem. Most auto parts stores and Home Depot carry the material. A can of resin with the hardener and some fiberglass cloth. Follow the instuctions on the can. Share this post Link to post Share on other sites
mavfreak 11 #4 Posted November 29, 2010 I would think that it would hold ok. Works on cars and they probably have more vibration going down a bumpy road than a mower deck. Might not be as permanent as metal welded in but should last for some time if done properly Share this post Link to post Share on other sites
WheelHorse_of_course 99 #5 Posted November 30, 2010 Fiberglass makes sense to me. I would stay away from bondo. In my experience bondo is an open invitation to rust. Just MHO. :thumbs: Share this post Link to post Share on other sites
Kelly 1,028 #6 Posted December 1, 2010 Remember this is just a band aid, not a real fix Share this post Link to post Share on other sites
tarcoleo 119 #7 Posted December 1, 2010 Thanks everybody. My question centers on a 48" deck picked up a few days ago with some rust holes on left side. Structurally the unit appears sound, though the PO had used some body filler to cover over grief. I will attempt to fit steel patches, 10 gauge, over the bad areas as a mosaic, and have the patches welded together. The assembly will then be mechanically attached to the underlying original structure with well placed nuts and bolts. Not welding myself, this approach will be a straightforward job for a weld shop. Comments? Tom in RI Share this post Link to post Share on other sites
WH854 44 #8 Posted December 3, 2010 Take a look at this stuff at POR15 INC http://www.por15.com/Putty-Fillers-and-Sealer/products/10/ Chas Share this post Link to post Share on other sites
mavfreak 11 #9 Posted December 3, 2010 Chas have you used that? Share this post Link to post Share on other sites
wallfish 16,036 #10 Posted December 3, 2010 Thanks everybody. My question centers on a 48" deck picked up a few days ago with some rust holes on left side. Structurally the unit appears sound, though the PO had used some body filler to cover over grief. I will attempt to fit steel patches, 10 gauge, over the bad areas as a mosaic, and have the patches welded together. The assembly will then be mechanically attached to the underlying original structure with well placed nuts and bolts. Not welding myself, this approach will be a straightforward job for a weld shop. Comments? Tom in RI Instead of having the patches welded together and then bolting them on, why not just have them welded on to the deck. If you can make the patches and grind the areas on the deck clean, then it should be a quick job for a welder. Share this post Link to post Share on other sites
WH854 44 #11 Posted December 3, 2010 I have used the POR 15 paint on the underside of a deck I re-did good stuff Chas :) Share this post Link to post Share on other sites
AMC RULES 36,961 #12 Posted December 3, 2010 I would think POR-15 would be the perfect solution to deck repairs. Their two part expoxy is the next best thing to welding, if you don't have the skills or machine handy. I've used it for many automotive restorations/repairs, works suprisingly great for dash underlayment repairs too, which is always a hard fix. I usually make a metal patch panel and sandwich it into place with POR-15. Dries hard as a rock, very easy to manipulate into place. Of course, welding would be the best choice. Share this post Link to post Share on other sites
WH854 44 #13 Posted December 3, 2010 Here is a link to the deck I painted POR 15 on the underside!!! http://www.wheelhorseforum.com/index.php?showtopic=18606 Chas Share this post Link to post Share on other sites
mavfreak 11 #14 Posted December 3, 2010 cool something to keep in mind for when I need to do some body work. Share this post Link to post Share on other sites
