Countdown To Christmas!
squonk
Tri rib tires
squonk
I'm trying to find a source for tri rib tires for my 704. The size is: 4.80x4.00x8. I've looked at Millers,Tires unlimited and a few others and haven't found any. This is basically a show tractor. The most work it will do is pull a wagon around. I've thought I'd seen pictures on here of roundhoods with these tires on them somewhere here. Anyone have a source or recommend another size that will work?
TT
Tucker Tire listing on eBay
If it's over before you get there, he has more. :thumbs:
Hopefully they're the better Deestones and not GBC (Greenball) brand. I have received both brands from him - so you might want to ask first before buying any.
He also has the 3.50 X 8 size - which might look better on the mid-engine tractors.
wheel horse 1045
other than looks do they work any better,ive never had a pair .
squonk
Thanks TT!! :wh::):thumbs: :)
TT
If they're used for what they are designed - which is soft ground / dirt, the answer is yes.
Otherwise, it's more for looks. :thumbs:
DMK855
I too bought mine from Jeds on Ebay!
Here is the link for the 3.5 X 8.
http://cgi.ebay.com/2-3-50-8-Mini-Puller-F...=item5ada31c616
Here is a link for the 4.00/4.80 X 8 from Morrow tire. They also have the 3.5 X 8.00 cheaper than Jeds. Don't know what brand though!!
http://cgi.ebay.com/TWO-New-4-00-8-Tri-rib...=item588641a9bb
Kelly
Where ever you get therm I like the Deetones much much better, they are better built.
wheel horse 1045
thanks TT
Sarge
I see on that European tires site there is a sawtooth in a 5.70-8 size that mimicks the oem front steer tires- V49 / V7516 in the Industrial section....hmm.
Sarge
HorseFixer
I like them also, I got mine from Morrow's and ordered a couple sets because he charges same amount shipping for multiple sets. When you get them they are all crunched down and lopsided, so just put tube inside & inflate this straightens them out. I keep mine that way in storage.
