Countdown To Christmas!
brianf
1267 PTO Clutch Disk
brianf
Anyone know the part # and/or where I can get a new clutch disk for a 1267?
daemon2525
If you have the old one, you can get new pads installed by companies that reline
truck brakes and clutches. We have one here in Fort Wayne.
I went to them without knowing whether they could or would do the job for me.
I went through the door ready to explain why I needed this little round thing relined and started to say ... I need this.... He cut me short and smiled :thumbs:
"Yup, we can do that! I have a wheel horse myself!"
They can put a better lining on them than they have originally and it is less expensive than a new part. (which is still available).
Don1977
It will be better to have the lining replaced because the new disk the metal is thiner than the older ones. This will cause the C-clips to ware out. I had to make a spacer to put behind the new disk. I took me two or so set of c-clips before I found the problem.
Aussie
Does any-one know if the later models without rivets are also rebuildable and if so how thick a new lining should be? The lining in my 416-8 is completely gone.
thanks
Don1977
thanks
I would guess 3/16" thick. I don't have a new one to measure. The one on my Wheel Horse measures 5/32" it's been on there at least 12 years. Maybe some one who has a newer one can measure theirs.
WH854
Posted on Yesterday at 11:21 pm
Are you talking about the Retainer Clips? As far as I can see there are no C Clips in a mechanical PTO :thumbs:
Chas
Don1977
Chas
Yes Retainer Clips they are shaped like a C. With a thiner clutch disk than the grove to the back of the sleeve, when you engage the clutch it puts pressure on the retainer clips
and will ware them out. I don't know when they change the thickness, but i would think all the later model Wheel Horses would have the thiner disk.
WH854
If the bearing race is not all the way against the drive pully, or the pully key is a little long and sticks out your race will not be up tight against drive pully,the race retainers will work loose. the retainers only hold bearing race on the shaft. I have run into that Problem, If the key sticks out a little to far the race will not fit in center of plate right. :thumbs:
Chas
WH854
Oh yea I've found a couple with the race put on with the grove on the outside. :thumbs: Backwards
Chas
