brianf 0 #1 Posted November 13, 2010 So I'm pretty sure I blew the diff out of my 1267 (5060 unidrive). 11 months ago I blew the connecting rod in the engine and just finally got around to getting her running. I've got grinding mostly when I turn the right wheel but the left mostly seems ok so I think the tranny itself is ok. Can I get parts for this diff somewhere if I where to tear it down? Share this post Link to post Share on other sites
stevasaurus 23,342 #2 Posted November 13, 2010 You are probably going to tear it down anyway...take some pictures and let's see what shows up. I am sure you can get parts...a lot of the transmissions parts are interchangeable...you could just have a bad axle bearing on one side. :thumbs: Share this post Link to post Share on other sites
KB9LOR 4 #3 Posted November 13, 2010 So I'm pretty sure I blew the diff out of my 1267 (5060 unidrive). 11 months ago I blew the connecting rod in the engine and just finally got around to getting her running. I've got grinding mostly when I turn the right wheel but the left mostly seems ok so I think the tranny itself is ok. Can I get parts for this diff somewhere if I where to tear it down? Just got done splitting and replacing gears on a 5049 tranny, as far as parts go, depends what parts and such, I would split it and see what the problem is, and if parts are available reasonably then replace, if high, look for a donor trans. Good luck and keep us posted. Share this post Link to post Share on other sites
brianf 0 #4 Posted November 15, 2010 Yep as I guessed, the differential is toast, although it's far worse than I imagined. Picture here: http://yfrog.com/mrl44cxj Also both roller axle bearings are destroyed, on one side the race is even gone. I did find someone offering a diff and/or a donor transmission. If I can get the rollers, I may just buy the diff, otherwise I guess I'll be looking at a new unit. Share this post Link to post Share on other sites
Duff 206 #5 Posted November 15, 2010 Yeah, I think it's safe to say that unit has some issues..... Duff :thumbs: Share this post Link to post Share on other sites
oldandred 15 #6 Posted November 16, 2010 Yep as I guessed, the differential is toast, although it's far worse than I imagined. Picture here: http://yfrog.com/mrl44cxj Also both roller axle bearings are destroyed, on one side the race is even gone. I did find someone offering a diff and/or a donor transmission. If I can get the rollers, I may just buy the diff, otherwise I guess I'll be looking at a new unit. dont think youre going to find a new tranny and if you do I hope you own a bank look for a 1967 867,1067,1267, 1968 raider 9,10,12 or any eight speed will work Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #7 Posted November 16, 2010 The 5060 isn't "total junk", but they're the worst of the 6/8 speeds - and since they're the first, a lot of parts are unique to that model. (including the crappy aluminum differential end caps) Get your hands on any of the C series ('76/'77 B60/80/100 too) or the 3/4/500 8 speeds, modify the brake rod, and you'll be back in business. :thumbs: Share this post Link to post Share on other sites
stevasaurus 23,342 #8 Posted November 16, 2010 brianf...here we go again. it would help to know where you are at...don't need a street address, but sw Ohio...central Ill....Conn. would be helpful. There may be members close to you that could help for far less money...talking about shipping. What I am trying to say is that, you can get a trans replacement and maybe pick it up close to you...rather then have it shipped for more then it is worth. That is why we have been trying to get new members to put there approx on their signatures...save a lot of time and posts. :thumbs: Share this post Link to post Share on other sites
brianf 0 #9 Posted November 16, 2010 Heh, by new I meant new to me of course I'm in Southern NH. Share this post Link to post Share on other sites
