kirby 0 #1 Posted November 11, 2010 I have a 73 8hp 4speed 1-0120. I went out this morning turned the key and nothing. So i got my multimeter checked the battery, thats ok. Starter checked out and so did the solenoid. I bypassed the safety switch for the Clutch break pedal and still nothing. my ? is is there a way to test the key switch or anything else i should check before buying a key switch. I also checked wiring and didnt see anything there. thanks for any help that comes my way, Kirby Attached Image Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted November 11, 2010 Wiggle the PTO engagement lever - or slam it back pretty hard into the disengaged position. If that doesn't do it, start testing each "leg" of the circuit until you find the cause. (battery to ignition switch {hold switch in start position} to PTO interlock switch to clutch pedal interlock switch to solenoid trigger terminal. Share this post Link to post Share on other sites
WH nut 553 #3 Posted November 12, 2010 When you say the started and Solonoid tested good how did you check it. Start first by appling 12V to the small terminal of the Soloniod. If it cranks the start and Solonoid is good and you need to back track the start circuit. If it doent crannk the make sure you have 12V going throught the large terminals of ther Solonoid Share this post Link to post Share on other sites
kirby 0 #4 Posted November 13, 2010 thanks for the help guys. Its fixed, it was the PTO safety switch. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #5 Posted November 13, 2010 :thumbs: Glad to hear you're back in the saddle. Share this post Link to post Share on other sites
