IthacaJeff 151 #1 Posted November 11, 2010 Hi WH'ers: I just made a lift cable for my moldboard plow using 1/8" cable and screw-on wire rope clips to make loops. The 1/8" cable is easy to bend and does not create overly bulky loops. However, I thought that I should beef up the cable for my other tractor that will be running a tiller. So, I got the next size larger, 3/16", and it is much harder to work with. I managed to put a fork terminal on one end of the wire cable (crude!), but the other end will need a removable loop or fitting. Using the wire rope clips makes for an overly bulky loop. . . usable but not pretty and potentially may hang up. Note that I am NOT using the lever system under the seat. The cable goes straight through the cable guide and to the hitch. So, my questions: Will a 1/8" steel cable handle the rigors of lifting the tiller? Or, Is there a better way to tie off the end of the cable? Thanks, Jeff in Enfield Share this post Link to post Share on other sites
Forest Road 594 #2 Posted November 11, 2010 What do you haveto lose if it breaks? Its certainly worth a shot. I've seen guys use a chain to the back of thei machine to raise and lower the tiller. Just a chain or rope tide behind the seat somewhere. Doesnt have to be pretty. Share this post Link to post Share on other sites
IthacaJeff 151 #3 Posted November 12, 2010 Well, ya' convinced me to just go for it. It definitely won't be pretty, but then again, neither is the tractor! Thanks, Jeff Share this post Link to post Share on other sites
