B-8074 20 #1 Posted November 4, 2010 I only have one good deck and it came with my 1969 Charger 12. Can I use that deck on my C-175 without having to put the modern deck hardware on it? My charger is disassembled for restoration and I want to keep the original deck for it. But like I said it's the only good deck I have. Thanks. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,557 #2 Posted November 4, 2010 Nope as far as I know you will need the mid mount tach a matic deck. I think it started in 73 or 74 :thumbs: Share this post Link to post Share on other sites
B-8074 20 #3 Posted November 4, 2010 I should've mentioned that the deck will mount to the tractor. I guess I need to know if I can use the front mule drive or if I have to pull the pully and brackets off the Charger. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,557 #4 Posted November 4, 2010 I am confused now. Are you sure it will mount on the newer machine? Was the Charger changed over to the mid mount at some point? Pics will help a bunch Share this post Link to post Share on other sites
B-8074 20 #5 Posted November 4, 2010 OK, this is the only pic I have right now. I can get more tomorrow. It dosen't use a front mule drive on the charger. The belt comes off the PTO to an idler pully on the side of the mid mount, the tensioner is on the deck. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,557 #6 Posted November 4, 2010 As far as I can see that deck will not fit the newer tractor. Share this post Link to post Share on other sites
B-8074 20 #7 Posted November 4, 2010 I'll get better pics tommorrow. Share this post Link to post Share on other sites
SgtBob 27 #8 Posted November 4, 2010 I have to agree with Stevebo, that is not an 80's deck ! Share this post Link to post Share on other sites
B-8074 20 #9 Posted November 4, 2010 I know it's not an 80's deck. It's a late 60's deck from a 69 Charger 12. I want to use the 60's deck on my early 80's trator. Share this post Link to post Share on other sites
mavfreak 11 #10 Posted November 4, 2010 I hadtoput the newer set up on the older deck Share this post Link to post Share on other sites
