nwh1-0475 0 #1 Posted April 23, 2008 Gentlemen, I am a new owner of a 10 Automatic Model # 1-0475. I used it for the first time this year last weekend and two of the bolts that hold the diff. together in the transmission were sheared in half and got under the ring gear and cracked the case. I took to somebody that said they could fix it and ended up doing more damage to it. I was wondering if I could find somebody who could actually fix it right will it be as strong as before it was broken or would it be better to try and find a different one. Thanks for your help. Share this post Link to post Share on other sites
refracman 167 #2 Posted April 23, 2008 nwh if the case is busted it can be welded but whoever does has to know how to weld cast. and you can either get the bolts, washers and nuts from Toro or find some grade 8s to replace them all, also you have to inspect the diff hubs and see if the bolt holes are wobbled out if so time for another trans, since replacements are not available You would most likely be better off gettin another trans. If you post where ya live maybe somebody here can hook you up. Good luck! Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,610 #3 Posted April 23, 2008 First off, . I don't think I can add anything more than what Steve has already said, but I do think getting a "new" transmission would be a good idea. Share this post Link to post Share on other sites
nwh1-0475 0 #4 Posted April 23, 2008 First off, . I don't think I can add anything more than what Steve has already said, but I do think getting a "new" transmission would be a good idea. Terry, I live in southwest mo, near springfield would you happen to have a case you would be willing to part with. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,610 #5 Posted April 23, 2008 Hi, fellow Missourian. I don't have a case, but there are a couple of members here from Missouri who might or could help. Dean (Eastcoastyankee) and Frank (Bowtieguy) might be able to hook you up with a case. :whistle: Share this post Link to post Share on other sites
nylyon-(Admin) 7,882 #6 Posted April 23, 2008 Welcome to RedSquare. You are probably better off just replacing the entire trans. You should be able to find one at a reasonable price and there are many which should fit. Again, and :WRS: Share this post Link to post Share on other sites
nwh1-0475 0 #7 Posted April 24, 2008 Welcome to RedSquare. You are probably better off just replacing the entire trans. You should be able to find one at a reasonable price and there are many which should fit. Again, and Ok, Since being new to the Wheel Horse World, what transmissions would fit this fine machine I have. So far other than the idiot that put grade 2 bolts in the differential I simply love this machine. I would like to find a grader blade for it, or could I use my dozer blade to level the driveway out. I have a snow blower for it but don't know if I will really ever have a use for it here in SW MO. Thanks for the help. Share this post Link to post Share on other sites
nylyon-(Admin) 7,882 #8 Posted April 24, 2008 You have a Sunstrand model 90-1136, this was used in the following: 74-75 B-100 74-77 C-120 Other Sunstrands would probably work as well. Share this post Link to post Share on other sites
nwh1-0475 0 #9 Posted April 24, 2008 You have a Sunstrand model 90-1136, this was used in the following: 74-75 B-100 74-77 C-120 Other Sunstrands would probably work as well. Does anybody have a tranny that they would be willing to part with? Share this post Link to post Share on other sites
baerpath 517 #10 Posted April 24, 2008 I do but I'm in NY. Not sure how bad shipping would be butI could take it to Pa and maybe we could find a ride towards you. I'm slowly parting a C120. Duane Share this post Link to post Share on other sites
nwh1-0475 0 #11 Posted April 24, 2008 I do but I'm in NY. Not sure how bad shipping would be butI could take it to Pa and maybe we could find a ride towards you. I'm slowly parting a C120. Duane Where are you at in NY? If you give me a zip code I can get a quote for shipping. Would you be willing to strap it to a pallet? How much do you want for it? Share this post Link to post Share on other sites
bowtieguy 334 #12 Posted April 28, 2008 Hey Springfield guy....just caught up with all the recent posts.....if you don't find a tranny, give me a call....most of my horses are on the farm near Clinton,MO..I might have one and will check next time I go to the horse barn.(if gas ever goes back to a price I can afford) There are a couple more WH guys in MO and KS that might have one so hang on until we check em out. or you can call my cell phone anytime after noon 816-806-9774 I'm bettin' we can find ya sumpin'....how about a whole tractor? PS... what is you name? Share this post Link to post Share on other sites
nwh1-0475 0 #13 Posted April 30, 2008 Well, I found another transmission at a lawn mower junk yard. It is a working transmission and the guy wants 350.00 for it . He also told me that he has a NOS transmission that he wants 1200.00 for . I guess I will keep looking. If'n anybody has a left hand case they want to part with for a Sundstrand Hydro trans #90-1136 let me know. Thanks. Share this post Link to post Share on other sites
nwh1-0475 0 #14 Posted April 30, 2008 I have found a case on e-bay but it is for a C-160. After looking at the all of the parts it appears to have 1 1/8" axle shafts, which won't work on my tractor. Can somebody verify this for me. If it will work let me know I would like to get the case. Thanks. Share this post Link to post Share on other sites
