jasoncracer 0 #1 Posted October 27, 2010 i dont really want down pressure cause i plow gravel and pavement i want to use chain now does any one have pics or ideas from the I hook do i go to the lever with a chain the down to the plow OR DO I GO FROM THE I HOOK STRAIGHT TO PLOW WITH CHAIN? Share this post Link to post Share on other sites
jasoncracer 0 #2 Posted October 27, 2010 :) please! Share this post Link to post Share on other sites
kajamo240 3 #3 Posted October 27, 2010 My plow frame was lengthened by about an inch and a half so I have to use the mower deck lift pin with a chain wrapped around it and into the hole on the plow frame. Works good but the plow is a little heavy. Share this post Link to post Share on other sites
nylyon-(Admin) 8,321 #4 Posted October 27, 2010 Check here, is this what you're looking for? Share this post Link to post Share on other sites
mavfreak 11 #5 Posted October 27, 2010 I have made skids to keep the plow out of the gravel. It worked great on my commando 800 but now that I mounted it on the C161 twin they won't work because they hit the tires. I also used the knob that sets height on the lifting arm but if you have any undulations in your driveway then it bounces and digs in or misses snow altogether. I think skids work the best. I will be trying to come up with some else soon I'll keep you undated on what I can figure out there is a thread that has how you hook up a plow its very useful Share this post Link to post Share on other sites
jasoncracer 0 #6 Posted October 27, 2010 that link is great what i did is minus mower deck arm its just resting on plow and put a chain from i hook to plow but i just go a bar with 2 pins exactally the same but longer it gooes from plow to were i hook should go is that better or chain setup i got going?? Share this post Link to post Share on other sites
