galaxiejoe 0 #1 Posted October 17, 2010 I am leaking oil from behind the governor arm on my WH, is there a seal I can get and how involved is it to replace. also so leaking oil and gas from the fuel pump, but I am waiting on on a new fuel pump. Joe Share this post Link to post Share on other sites
WH nut 553 #2 Posted October 17, 2010 I believe thats a machine fit on the shaft, If its leaking much oil Id check your breather to make sure its not pluged. The breather is under the carb in the valve cover 1 Share this post Link to post Share on other sites
galaxiejoe 0 #3 Posted October 20, 2010 Its not leaking a lot but it is weeping enough to get the points cover and frame wet. Share this post Link to post Share on other sites
WH nut 553 #4 Posted October 20, 2010 Check the breather and make sure its clean Share this post Link to post Share on other sites
