galaxiejoe
oil leak help
galaxiejoe
I am leaking oil from behind the governor arm on my WH, is there a seal I can get and how involved is it to replace. also so leaking oil and gas from the fuel pump, but I am waiting on on a new fuel pump.
Joe
WH nut
I believe thats a machine fit on the shaft, If its leaking much oil Id check your breather to make sure its not pluged. The breather is under the carb in the valve cover
galaxiejoe
Its not leaking a lot but it is weeping enough to get the points cover and frame wet.
WH nut
Check the breather and make sure its clean
