KyBlue
New Purchase
KyBlue
I recently aquired a 76 B60 (the WH says B80, but the model comes back to a 60)
One of my EPay finds. Its in pretty good condiition really but it has a few things that need attention.
Belts, I need to replace the belt to the deck, and the one ON the deck as well as the drive belt. The ones I have are so worn, all the writing is gone..haha
The Fuel Line from the Tank to the pump, is it SUPPOSED to run under the cover on the motor? or is it supposed to go another way? Pics would be great!
There appears to be something blocking the outlet in the fuel tank. Before I reach down and pull this out, is there a filter or something in there?
The Fuel Bowl on the Carb is leaking at the top, is there supposed to be a gasket, or is it just a metal/metal fit?
Thanks for the help ya'll!!
KyBlue
No Help? Ahh well. I got the deck belt and the Bowl Gasket ORdered... Still need the belt to go from the motor to the deck.
Thanks for any help ya'll can give..
Buzz
What model # is your tractor and do you know the model number of the deck? How big is it and is it side or rear discharge. According to Toro the side discharge takes a # 102741 belt, croses over to Gates # 6638BR
KyBlue
Model is 61-08k801 the serial # stamped on the sheet is 6316
Photo of the ID plate
The deck is another story its a 36" rear discharge, I havent found any kind of #'s off it.
Buzz
Go back to Toro's MPV at
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro
Enter model number 61-08K801. When that comes up click on "assembly drawings"
then when that opens click o "view attachments and accessories". That will give you a list of what attachments were available. You'll see that the rear discharge deck was model # 65-36XR01. Enter that number for model number and see if that's the deck you have. It shows it takes a # 102741 belt.
KyBlue
Thanks.
