MaineDad 87 #1 Posted October 11, 2010 Guys, I did some searching on RS on how to remove the electric clutch on my B-100, but I still need help. I removed the bolt in the middle of the clutch with no problem. I read in other threads to use a 5/8 bolt about 6 inches long to pressure the clutch off the shaft. My question is do I use the same size bolt that I removed, just longer? The bolt I removed is 7/16 fine thread that has a 5/8 hex head. Thanks, Share this post Link to post Share on other sites
Kelly 1,035 #2 Posted October 11, 2010 If you look in the end of the clutch it has threads in it, you need a 5/8" thread bolt, I put a washer or two coated with grease on the end of the crank so you don't scar the crank up, I now have a automotive A/C compressor clutch removal tool that works so much better, and it will also install them with out pounding on them, you might take the tractor, to a auto shop that does A/C repair and have them press it off. 1 Share this post Link to post Share on other sites
MaineDad 87 #4 Posted October 12, 2010 Ok got the big bolt and used some grease and a couple of washers. Problem is, I cannot stop the PTO/shaft from spinning. I have tried huge C-clamps and brute strength. Any other tricks or suggestions to stop it from spinning? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,852 #5 Posted October 13, 2010 Get 10 feet of clean rope and stuff 3 feet of it into the spark plug hole so the piston can't go past TDC. Garry 1 Share this post Link to post Share on other sites
Aldon 4,828 #6 Posted August 24, 2015 This thread was helpful. I was trying to determine counter force and this explains. Thanks gents. Share this post Link to post Share on other sites
