Pollack Pete 2,273 #1 Posted October 10, 2010 Quick question.I have several Wheel Horse tractors.Every one,up to and including 8 horse power,the width of the engine rests on the frame rails and they have 4 mounting bolts.On the 10 horse and larger engines,the engine is wider than the frame rails and the only place where they're bolted to the frame is on the flywhel side.Clutch side hangs over the frame rail with no bolts.What am I missing here on these larger than 10 horse tractors? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted October 10, 2010 Look up under the right frame rail. :) Share this post Link to post Share on other sites
Dave M 0 #3 Posted October 10, 2010 Pete, where the engine "hangs over" the frame, the bolts are underneath the engine. The bolts pass through the frame into tapped holes on the underside of the oil pan. A little hard to get to, but you'll find 'em. Share this post Link to post Share on other sites
Don1977 605 #4 Posted October 10, 2010 Unless the engine has been changed there are bolts up from bottom into the oil pan. Share this post Link to post Share on other sites
dandan111 44 #5 Posted October 10, 2010 I know a guy who used heavy u-bolts to hold it to the frame on the pulley side of the engine. The engine hangs over the frame like 1/2 inch or so. He said that in the old days this was how it was done? It looks like it should hold fine on his. Share this post Link to post Share on other sites
KC9KAS 4,744 #6 Posted October 11, 2010 The right front bolt for my 1975 B-100 Automatic is a "J"-bolt that is factory. Share this post Link to post Share on other sites
Kelly 1,035 #7 Posted October 11, 2010 One of the B series tractor I believe the mid length frame tractor 74 or 75 had the J bolt as there is not room for a bolt from underneath, because the axle is in the way, but I could be wrong??? Share this post Link to post Share on other sites
wallfish 18,788 #8 Posted October 11, 2010 I used four J bolts to hold the 12hp down on my Rat Rod, no through bolts at all. Works fine Share this post Link to post Share on other sites
