stoneman 10 #1 Posted October 8, 2010 according to my information, WH made 2 different rear tachmatics. will the one from my Work Horse 700 work on the GT-14? i was hoping i could use it to mount the 3 point mounting plate. if i ever add a plow though, i think it'd have to be the right one. thanks . . . scott Share this post Link to post Share on other sites
stoneman 10 #2 Posted October 10, 2010 bump. still :) Share this post Link to post Share on other sites
Brrly1 1,146 #3 Posted October 10, 2010 Scott, the best thing that you could use would be a three point hitch. They made two different setups for the GT14. The main one that was used was the three point that used the mid-lift cylinder that raised the mower deck and grader blade things like that, that attached underneath the tractor. It had a long bar that travel thru the mid area of the tractor and attached to the rear three point. The other system had the cylinder attached to the rear bracket on the three point. It also had its own independent lift valve mounted to the side of the tunnel area by you left leg,or knee. 8-4121 is the model # that uses the independent valve and cylinder. I am not real sure on the other model as I will have to do some checking on that. I will see if I can get that done later today. have a great day. See Ya, Bye Burly :USA: Share this post Link to post Share on other sites
