mattd860 162 #1 Posted October 8, 2010 Can somebody post a picture of the throttle & choke linkage routing (from the levers to the engine)? I also need picture(s) of the Lauson H55 engine from a Suburban 550 All the carburetor linkage is missing (governor linkage, spring, etc). Right now the throttle line goes directly to the throttle butterfly. Thanks Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #2 Posted October 8, 2010 Here are 2 HH55's The one on the left is for a 60 and the right for a 61. You may be able to pan in a bit to check it out. Good luck- Share this post Link to post Share on other sites
mattd860 162 #3 Posted October 8, 2010 Thanks. That helps. Now I just need a picture of then engine on the tractor showing the throttle & choke cable routing. Share this post Link to post Share on other sites
