pumper.atv 26 #1 Posted October 1, 2010 I just picked up a transmission a while back and it has 1inch axles. I know the lawn ranger used it but what else did? Looking at buying a Commando 8, did that use 1inch axles? :USA: Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted October 1, 2010 Ummmmm...... there were only a few three (four) speeds that didn't have one inch axles. Did you look for any numbers cast into the cases? Does it have short, medium, or long axles? Is the brake drum on the countershaft or the pinion shaft? Yes -- the Commando 8 would have one inch axles too. Share this post Link to post Share on other sites
pumper.atv 26 #3 Posted October 1, 2010 Which one is the pinion shaft and the counter shaft Axel length? :USA: Share this post Link to post Share on other sites
snookman1 1 #4 Posted March 25, 2011 the 74'- 75' b80 run with 4spd 1" axles in a model number 5084 unidrive transaxle. hope this helps. Share this post Link to post Share on other sites
sorekiwi 761 #5 Posted March 26, 2011 Ummmmm...... there were only a few three (four) speeds that didn't have one inch axles. . Wow Terry, thats something I've never seen. Which 4 speeds had 1 1/8" axles? Have you ever seen a 1" axle trans, with anything other than a 4 pinion diff? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #6 Posted March 26, 2011 Which 4 speeds had 1 1/8" axles? Have you ever seen a 1" axle trans, with anything other than a 4 pinion diff? The 3 speed Uni-Drives used in the 953/1054/1054A/1057/1257 had the (long) 1 1/8" diameter axles. I'm not positive, but there may have been some bevel gear differentials that used 1" axles. Share this post Link to post Share on other sites
sorekiwi 761 #7 Posted March 26, 2011 Thanks Terry! I actually have a 1057 sitting in my driveway and hadnt noticed the axles before. But in my defence, I've only owned it for 6 hours!! Sorry for the hijack there Pumper! But it is kinda relevant... :thumbs: Share this post Link to post Share on other sites
Kelly 1,033 #8 Posted March 26, 2011 I don't think you hijacked a thread this old..... Share this post Link to post Share on other sites
sorekiwi 761 #9 Posted March 26, 2011 Oops, didnt notice... :thumbs: Share this post Link to post Share on other sites
Kelly 1,033 #10 Posted March 26, 2011 But it is good info, I have a 1257 out back, I need to check it out. Share this post Link to post Share on other sites
