Pirate 0 #1 Posted October 1, 2010 I want to get a small winch for implement lifting/downforce, plow lift, etc. What winches are you guys using, price, strength, etc, and what you think of it. Share this post Link to post Share on other sites
Forest Road 594 #2 Posted October 1, 2010 I can't imagine how a winch would place any downforce on anything. But I had a couple sup $100 Ebay specials on ATV's. If you want a name brand go get a Warn or Ramsey. But for about $100 I pulled my ATV's out more than once. It had to be a few thousand pounds of pull. Have fun w/ it. Be sure to use the relays. Share this post Link to post Share on other sites
wallfish 18,441 #3 Posted October 1, 2010 You would have to rig up some sort of pulley system to get down preasure using a winch with a cable. An actuator might be a nicer and easier setup. Share this post Link to post Share on other sites
Pirate 0 #4 Posted October 1, 2010 I can't imagine how a winch would place any downforce on anything. But I had a couple sup $100 Ebay specials on ATV's. If you want a name brand go get a Warn or Ramsey. But for about $100 I pulled my ATV's out more than once. It had to be a few thousand pounds of pull. Have fun w/ it. Be sure to use the relays. The shop made 3 pt setup, had a winch mounted between the lower and upper arms. By putting the lift cable on the lower arms, it raised it, and if you put it on the upper arms, it applied pressure. Not very convienent, but for some applications, might be useful. Of course, I can't find the post with the picture :wh: Share this post Link to post Share on other sites
