puddlejumper 67 #1 Posted September 30, 2010 Was wanting some info on throttle and choke linkage. The linkage that was on it was definetly wrong so I set it up like my 33r which I am99% sure is original (linkage mounted to blower housing) will this be factory correct for the 552? Also should this tractor have a exhaust support from the case of the engine? Thanks for any help I know this may be trivial to some degree but I just want original if possible. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted September 30, 2010 No exhaust support, but they did use a bolt-on exhaust "manifold". This pic is of a 32E, which is the same as the 552: (ignore the incorrect air cleaner assembly) The throttle linkage was on the blower housing, but I don't have any pictures that show it clearly. Share this post Link to post Share on other sites
sorekiwi 761 #3 Posted September 30, 2010 This is from a 502: I know that Terry is right about 99% of the time, but mine had an exhaust brace: Share this post Link to post Share on other sites
puddlejumper 67 #4 Posted September 30, 2010 Well that was helpful, anybody have one of those exhaust flanges they would part with. I was hoping for the support bracket because the inner threads on my block are about shot and need all the help they could get.That is the first time I have seen that flange and it would cure the problem with the bad threads. It wont look just right but I believe I can machine a rectangular one If I cant find one. And still put the brace under it for comforts sake. I will have to kick around in the rocks and cipher on that one for a while Thanks guys. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #5 Posted September 30, 2010 Now that you mention it - I have seen the braces on a few 62 models. (but none still had the original HT Lauson ~ including my 502 & 552) Perhaps they were added part way into production? I can't help with the bolt-on manifold, but I might have an extra brace here somewhere. Share this post Link to post Share on other sites
puddlejumper 67 #6 Posted September 30, 2010 TT I have lost your wish list from earlier adventure but resubmit and we will do some trading. Share this post Link to post Share on other sites
sorekiwi 761 #7 Posted September 30, 2010 Mine had the brace, but there was no U-bolt to hold he exhaust steady. It had pulled the threads out of the block, and cracked through the side of the exhaust port. I had a friend weld the block back up, then did the machining to refit the exhaust manifold. Foumd another blurry picture of the carb part of the linkage: Share this post Link to post Share on other sites
puddlejumper 67 #8 Posted September 30, 2010 With that info it gets the brace original or not (with the clamp of coarse). Im satisfied with the linkage its identical to my 33r Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #9 Posted September 30, 2010 Looky what I found in the shop! One NOS #5646 (old #2297) exhaust brace complete with genuine OEM female u-bolt! (I know you'll get the "female" joke.) You know how to find me...... and I might even be able to find that grocery list again. :) Share this post Link to post Share on other sites
puddlejumper 67 #10 Posted September 30, 2010 TT I was looking at the head shroud on the picture you posted and was wondering if there was just bushings under it with longer head bolts to make up for the 3 recessed head bolts holes in the head, mine and kiwis are the same ,where that head appears to be flat like a h60. Ill PM you later to swap Info;going to go tinker in the shed. Share this post Link to post Share on other sites
puddlejumper 67 #11 Posted April 2, 2011 FOUND IT!!! Share this post Link to post Share on other sites
sorekiwi 761 #12 Posted April 2, 2011 And it only took 6 months of searching for one! Great score! Share this post Link to post Share on other sites
Kelly 1,033 #13 Posted April 2, 2011 But that one is no good the gasket is broken. Share this post Link to post Share on other sites
puddlejumper 67 #14 Posted April 2, 2011 Yea, Kelly maybe I should send it back. Share this post Link to post Share on other sites
