pumper.atv 26 #1 Posted September 26, 2010 Can i put a round air filter off a 12hp kohler on it for now? and is the recoil specific to the little one or will others fit Share this post Link to post Share on other sites
rmaynard 16,701 #2 Posted September 26, 2010 What engine do you have on it now? Share this post Link to post Share on other sites
pumper.atv 26 #3 Posted September 26, 2010 Original Kohler :) Share this post Link to post Share on other sites
VinsRJ 723 #4 Posted September 26, 2010 If that is the original motor its either a K90 or K91. K91's showed up in later production RJs. Either way alot of parts swap between the 90's and 91's. You can run a round filter on these tractors. I do believe though the 12hp filter will have a larger opening than your carb inlet air horn. But if it fits, its fits and it will work. As for the recoil, your machine would have had a Kohler, Schnacke or Fairbanks. From the starter cup on the flywheel I would say your unit had a Fairbanks on it at one time. And yes the K90-91 recoils would have a small or smaller bolt mount spacing than its K-Series brothers. Share this post Link to post Share on other sites
sorekiwi 761 #5 Posted September 26, 2010 The RJ I used to have had a Tecumseh recoil on it. The hard part is finding the right depth cup to go on the flywheel. I ended up "cutting and shutting" a deep tecumseh cup to suit mine. Share this post Link to post Share on other sites
