grinchsr 650 #1 Posted September 26, 2010 I picked up a 416-8 today with a Kohler 16 horse. Someone cleaned the engine so good that they removed the numbers off the engine tag. Does anyone know what the code should be? I also have a Walbro carb with the part number - 4785320-S. Will this carb work on this tractor? The numbers off of the tractor are - 3116K804 27279 7240 What year tractor is this? SORRY for all the questions RAY Share this post Link to post Share on other sites
tommy3horse 3 #2 Posted September 26, 2010 Hello Ray; On the carb, there should be a "30" cast into the choke side of the carb, on the inside, at the top of the throat. Good luck! Oh, and Tom :USA: Share this post Link to post Share on other sites
gwgdog66 23 #3 Posted September 26, 2010 It should be a 1988, base on the tractor Mdl#, and it should have the 16 HP Kohler Magnum M16S-Spec 711523 Oh Yea :) Share this post Link to post Share on other sites
tgranthamfd 29 #4 Posted September 26, 2010 Here is an IPL for the carb and brackets for the Mdle # for the tractor. https://homeownersolutions.toro.com/portal/...wingDiagramPage Just Type your MDL # in 31-16K804 Share this post Link to post Share on other sites
grinchsr 650 #5 Posted September 26, 2010 Thanks to Tom & Gary The carb has the number 52 in the throat. What does it fit? Share this post Link to post Share on other sites
gwgdog66 23 #6 Posted September 26, 2010 Possibly a K series K341 http://www.mowergraveyard.com/john-deere-3...e8baeccb8e2c1a7 Share this post Link to post Share on other sites
