RPR 0 #1 Posted September 23, 2010 I got some positive reapnses to my last question, but now have to make a decision. Last night I ran across a 314-8 with plow. Looks very nice, but has almost 1,000 hours. I have been looking at a C-121 with around 700 hours with snowblower. It also looks nice for its age. Any suggestions, or things to be aware of, since I am new to the WH line? I am hoping to blow snow/ till garden with the tractor I purchase. I would like to make a decision today as vacation starts tomorrow. Thanks Share this post Link to post Share on other sites
RPR 0 #2 Posted September 23, 2010 BTW...prices are nearly the same for both outfits. The 312-8 is $100 cheaper, but it does not have the snowblower. Share this post Link to post Share on other sites
RPR 0 #3 Posted September 23, 2010 Sorry...it is a 312-8 not a 314-8 Share this post Link to post Share on other sites
Kelly 1,037 #4 Posted September 23, 2010 They are basicly the same tractor with diff. tin on them, the C-121 would not have had a hour guage so I guess the hours are a guesstiment?? look for leaking axle seals, check the trans fluid, under the seat is a dip stick, it is not uncomon to find water in them, but maybe one is clean, engines that run right with no smoke, if they are about the same after checking them over I'd offer a bit less and go for the one with the blower they cost about $200 for a good one. Share this post Link to post Share on other sites
kpinnc 17,153 #5 Posted September 23, 2010 The C121 will have the heavier-duty 8 speed transmission with 1 and 1/8th inch axles and an 8-pinion differential. The 312 will have the lighter duty rear end. It has 1 inch axles and a 4-pinion differential. This is still a very stout transmission. Unless you plan on very heavy pulling applications, this will not make a difference. The lighter rear end will stand up to plowing or any other "ground engaging" tasks. But the C121 transmission will handle basically anything you throw at it. Kevin Share this post Link to post Share on other sites
tgranthamfd 29 #6 Posted September 23, 2010 If kept outside by the P.O. the 312 could have more electrical issues than the 121. Seems like they had issues with the molex connectors and some of the component boards, if not taken care of. Share this post Link to post Share on other sites
gwgdog66 23 #7 Posted September 24, 2010 Drive both before you purchase. Pick the one you like best. Be aware though, you may eventually end up with two or more :) Share this post Link to post Share on other sites
RPR 0 #8 Posted September 24, 2010 Well I did buy the 312-8. I want to use the tractor for tilling, and decided the gear drive might be better for that, although I have tilled with hydro's in the past, having no trouble. The 312 was clean, whereas the 121 had rough paint, leaking rear axle, and once in a while I could hear an inner knock. Plus, the 312 was cheaper, with delivery included. Now, if someone knows of a good snowblower to go on the 312, in or near lower MI, I will be all set. Thanks for all of the input. Share this post Link to post Share on other sites
kpinnc 17,153 #9 Posted September 24, 2010 Sorry for the misleading info on trannies. I did not know the 121 was an automatic. Kevin Share this post Link to post Share on other sites
WheelHorse_of_course 100 #10 Posted September 24, 2010 Plenty of horse in lower MI and upper IN, so keep your eyes open. If you do not know about www.searchtempest.com you may want to check it out. It allows you to search multiple Craig's lists. When buying a blower be sure it had the "flag" and lift pole. You can substitute 2x4 for the pole, but the flag is necessary. Good luck :) Share this post Link to post Share on other sites
