KC9KAS 4,746 #1 Posted September 20, 2010 Went to an old fellows house today to look at a couple of WH tractors . He had a Charge 10 and a Charger 12 . He wanted $400 for the 10, and $1000 for the 12, but was about $1200 too high for the both of them ! I did end up with a 36" WH tiller for $25 . The tines turn fine when the large pulley is rotated. There are some other idler pulleys (rusted tight) with this, but I have no idea if they belong with this tiller or not. If someone can help with a model number, I can look for a picture book and see what it fits, and if I have all the goodies. http://i762.photobucket.com/albums/xx264/kc9kas/wheel%20horse/GEDC0131.jpg[/iM Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted September 20, 2010 7-1211 ~ used on most of the "normal" garden tractors up until 1973-ish when the Attach-Matic hitch system was introduced. I had one identical to it that came with a 1969 Charger 12. Share this post Link to post Share on other sites
HankB 16 #3 Posted September 20, 2010 I have nothing to add except to get your third picture posted. (Needed a "G]") -hank Share this post Link to post Share on other sites
wheel horse 1045 2 #4 Posted September 20, 2010 you can use that tiller with the quick attach front pulley system instead of those old pulleys,that's how I'm running mine on a C160 Share this post Link to post Share on other sites
KC9KAS 4,746 #5 Posted September 20, 2010 Thank you Hank...wondered what happened to the 3rd photo! Thanks TT & WH1045 for the info. The guy had a Charger 12...don't know the year...maybe the tiller was for it! The guy also had a 1045 that was his normal yard mowing tractor. All his tractors were inside and looked good, just too much $$ for me! He also had a 1931 FORD in his garage! Share this post Link to post Share on other sites
Raider 2 #6 Posted September 21, 2010 You're missing a belt guard and two belts. Or make/buy a newer style mid-attach idler like WH1045 suggests and run it on one long belt. I have that tiller on my Raider and changed it over that way. You'll need to use the old hitch with the pulley on it unless you want to really start changing things. I'll try and get a couple of pics of what I changed. Share this post Link to post Share on other sites
KC9KAS 4,746 #7 Posted September 21, 2010 I was hoping someone could me work towards the 1 single looooog belt to run this thing! It looks as though it attaches directly to the back axle, and the up/down lever operates it up/down via the cable to the back below the seat. Share this post Link to post Share on other sites
MikesRJ 558 #8 Posted September 21, 2010 The manual might help you out some: 7-1211 Manual Share this post Link to post Share on other sites
Retired Wrencher 6,450 #9 Posted September 22, 2010 :) Ken nice set up check it out with the bearings she if she turn over and put here to work. Gary B........... Share this post Link to post Share on other sites
520HC 208 #12 Posted September 22, 2010 Actually this drive system works very well. Share this post Link to post Share on other sites
Raider 2 #13 Posted September 22, 2010 Here's how I've changed mine to work with a single belt under the tractor. I bought the belt before making the front idler and built the idler to fit. I had to mount the tiller as far to the right as I could in order for it all to line up since I eliminated the double pulley idler. The rear lift uses the hole through the center of the slot hitch. The tiller mounting hitch is supposed to have that bend in the center of the round bar to clear the back of the transaxle. Share this post Link to post Share on other sites
