Countdown To Christmas!
puddlejumper
New Tractor
puddlejumper
Hi guys,
Been awhile, hope everyone's doing okay. I have an identifying problem and can use some help.
Due to the hood and hood stand and no sign of a solenoid ever being mounted in the toolbox, I brought home what I thought was a 400 Suburban on Tuesday. But, when comparing to my 550, now I don't know what I've got. Either my 550 is a 551 with a 550 hood or my new tractor is an RJ with a 60 hood and hood stand.
PICTURE COMPARISON
550 Straight Shift Lever
New Tractor Bent Shift Lever
550 Angle Side Plates on Front of Transmission
New Tractor Squared Off Plates on Front of Transmission
New Tractor has what appears to be a hood mounting strap on front of frame that 550 does not have
550 Has Flat Bar for Clutch Pedal
New Tractor has Round Stock for Clutch Pedal
Here are more miscellaneous pictures of new tractor, any suggestions on what make and model this tractor is would be appreciated. Or, let me know if my 550 is really not a 550.
buckrancher
I'am thinking 401
the 551 has the 701's cast trans. cases the shift lever may not be stock looks
like a newer one late 702 and up
the pedal you are showing I believe is for ingaging a belly mower not a clutch pedal
the clutch pedal should be on the left side as your other tractor
it does have one 1960 foot pad (left side )one homemade on the other
what you call the hood mounting strap does not belong there
hopefully someone else will chime in
Brian
TT
The "new" tractor is definitely a 1960. I would lean more towards a 400, but that doesn't mean that it couldn't be a 550 either.
A lot can change or be changed in 50 years, so you can't always go by what's there now.
Someone sure did a nice hack job on the tranz side plates though. :)
puddlejumper
thanks guys. I never considered somebody cutting off those side plates. It pretty much all falls into place now. Put an original shift lever back in it and everything else is cosmetic.
