Rideawaysenior 28 #1 Posted September 19, 2010 Okay, here is a stumper. I've got a K301 newly rebuilt block. The carb was rebuilt by me and I've done dozens with no problem that work fine. I did this one to spec as well. The problem is, the engine will start and run, throttle up and idle great for about five minutes. Then the engine will slow on idle and then stall. Sometimes it will start again and then there are times that it won't. The float is set to spec, the jets are set to spec, the fuel pump is good and the valves are not sticking. What is my problem? Could I just have a junk carb? :) Share this post Link to post Share on other sites
multihobbyguy 35 #2 Posted September 19, 2010 I had a coil that would do that to me on a Cub Cadet. It would start and run but it would heat up and quit on me. I have no idea why it happened but when I swapped it with another tractor the problem moved to the other tractor. Just my own experience, although it seems you think you may have a fuel problem. Do you have a fuel line collapsing on you? Share this post Link to post Share on other sites
Rideawaysenior 28 #3 Posted September 19, 2010 Nope, new fuel line. Engine is on a mount and the fuel line is submerged in a full gallon can. Share this post Link to post Share on other sites
Anglo Traction 761 #4 Posted September 19, 2010 Never doubt your own work. Accuracy is no Accident !. I agree , my money is on the iffy HT Coil . Share this post Link to post Share on other sites
Kelly 1,037 #5 Posted September 19, 2010 First you need to figure out if it is a fuel or spark problem?? then troubleshoot from there, check for spark with the no start issue, if you have spark give it a small shot of carb cleaner to see if it will fire. Share this post Link to post Share on other sites
Dale 0 #6 Posted September 19, 2010 check the main jet needle make sure the little holes are open Share this post Link to post Share on other sites
Rideawaysenior 28 #7 Posted September 19, 2010 Needle is super clean. I snaked the jets as well as the holes in the needle with some thin wire. Just a standard practice for me when rebuilding a carb. I guess I'll try a coil. I've got a couple kicking around. Share this post Link to post Share on other sites
Dale 0 #8 Posted September 19, 2010 is your vent open on gas cap Share this post Link to post Share on other sites
Duff 206 #9 Posted September 19, 2010 is your vent open on gas cap Dale, I think he's working from a test mount and just pulling out of a one gallon portable tank. Good thought on the tank vent, though, as that's certainly been known to cause a similar problem on tractors. ~Duff :) Share this post Link to post Share on other sites
