1962adrian 0 #1 Posted September 18, 2010 Hello from Holland, recently bought this C-141 , it is made/ assembled in Belgium, 30 years old and still running smooth, build a subframe for it and attached a home built snow plow for it, still need some snowchains for it, than let the snow fall (if any!) Cheers,Ad Share this post Link to post Share on other sites
Trouty56 567 #2 Posted September 18, 2010 What kind of subframe did you build? I'd like to see how you connected it up. Is that a light above the plow?? Gives you light where you need it. Nice driveway too!! Share this post Link to post Share on other sites
Retired Wrencher 6,183 #3 Posted September 18, 2010 :) HI 1962 nice tractor I have in the auto form these are a beast. I only use it for plowing my self. you will get a work out with out the power lift though?? unless u used light materiel. Well it looks like a fine worker enjoy it and T/Care Gary B..... Share this post Link to post Share on other sites
Retired Wrencher 6,183 #4 Posted September 18, 2010 oops sorry about the flag 1962 Share this post Link to post Share on other sites
1962adrian 0 #5 Posted September 18, 2010 Hi, here a picture of the subframe and the lift system , its manual, using the lift lever. The tractor came with a mower deck, (heavy!) it caused tears in the metal plating around the lift-lever shaft bushing. I welded the bushing in place, so no more play there. Thanks for the comments!, Ad Share this post Link to post Share on other sites
wh1257 226 #6 Posted September 18, 2010 :) hello i'm from belgium this tractor tays for long time of marktplaats and :) Share this post Link to post Share on other sites
The Toolman 22 #7 Posted September 18, 2010 Looks like a helluva nice job to me.... Share this post Link to post Share on other sites
stevasaurus 23,521 #8 Posted September 18, 2010 Well done Adrian...we are ready for snow. :USA: Share this post Link to post Share on other sites
racinfool40 203 #9 Posted September 18, 2010 :) I'd say great job on the fab.And looks like a great little worker!! Share this post Link to post Share on other sites
Duff 206 #10 Posted September 19, 2010 Adrian, that's a beautiful job of fabrication. Nice work! Duff :wh: Share this post Link to post Share on other sites
jusjeepn 59 #11 Posted September 19, 2010 I like your spring assisted lift. This setup looks a lot like how the vert shaft machines are set up, except for the cantilever lift set up! Very nicely done! :) Share this post Link to post Share on other sites
hm12460 53 #12 Posted September 19, 2010 looks like a well thought out and engineered lift. how hard is it to lift? your craftsmanship is excellent. Share this post Link to post Share on other sites
bustedglass 1 #13 Posted September 20, 2010 Nice tractor and plow. Good job on the mounting fabrication. Thank you for sharing . Share this post Link to post Share on other sites
