Countdown To Christmas!
ricky115
Need a belt #
ricky115
anyone got a number for the starter generator belt for a 876, thanks..rick
TT
It's supposed to be WH #1583 - which is (roughly) a 3/8" wide by 31.5" long V belt.
If you attempt to find one at an auto parts store, try either a 3V315 or a 3V310 (a little shorter).
Sometimes there's enough pulley groove wear that the original belt is a bit too long.
Retired Wrencher
:USA: :wh::) I believe Terry is write I could check out the 857 to see if this machetes up. But i am sure that is a good # T/C Gary B....
MikesRJ
Teach a man to fish ...
Here's the manual for that machine: http://www.mywheelhorse.com/graphics/file/..._876_OSMIPL.pdf
... and the parts manual for the K181: http://www.mywheelhorse.com/graphics/file/...P_TP-2045-B.pdf
Kohler parts manual says 270415 for the belt, buts it's a discontinued part.
Retired Wrencher
:USA: :wh::) I just looked the belt # that is on the 857 is a kohler belt and it is 231605df the gen is about 1/2 way up towards the tank I do not know if this is the wright belt but it does work fine.and I did buy from a W/H dealership. so ?? i hope this helps. Gary B...
