Shuboxlover 482 #1 Posted September 4, 2010 Now that I got the 520-H up and running, I took her for a test drive (MAN I LOVE THE STEERING REDUCTION!!!!!) But the thing almost goes as fast in reverse as it does forward. What gives? Is it simply just an adjustment? Or worse? Share this post Link to post Share on other sites
wheel horse man 56 #2 Posted September 4, 2010 :) :USA: Share this post Link to post Share on other sites
Shuboxlover 482 #3 Posted September 4, 2010 here ya go http://www.wheelhorseforum.com/index.php?showtopic=21087 Share this post Link to post Share on other sites
Kelly 1,033 #4 Posted September 4, 2010 And the problem is?? I wish mine went fast backwards, Now I'm guessing it does not go forward very fast or as fast as you would like, if you lift the seat you will find a square hole your adjustment is there I'm not very good at typing what I want to say but I will tell you it's not hard, there is a cam/plate with a slot in it and a bolt that goes in the slot if you turn that bolt a little bit it will make a diff. in forward and back, I played with the settings on mine for a day till I got it where I like it. Share this post Link to post Share on other sites
Shuboxlover 482 #5 Posted September 4, 2010 Thanks Kelly, I'll play with it and let you know what I find. :) Share this post Link to post Share on other sites
