Butch 194 #1 Posted September 3, 2010 On the front side of the control valve there is a piece that looks like a hat that is held on to the valve assembly with two screws. The manuals, or the ones I have, don't show the details inside that cap. I took it off for rebuild purposes and by the time the parts finally came I forgot how it went together and which parts go inside. Does anyone have a pic or sketch of what goes inside and in which order? Thanks. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted September 3, 2010 This, maybe???? Share this post Link to post Share on other sites
Butch 194 #3 Posted September 3, 2010 That looks pretty close to what I have. I'll see if it works. Thanks. What manual did that pic come from? I have several and nothing. Thanks again. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted September 3, 2010 It came from the section of one of my older 2" thick "covers all brands" manual. Naturally, I can't think of the name of it, and of course it's out in the shop. :) Share this post Link to post Share on other sites
Butch 194 #5 Posted September 3, 2010 It went together that way! It doesn't feel smooth though. But I can't check it out until I have all the hydraulic lines on and I had to order a new tube that goes to the filter because I think I kinked it too much. Argh!! Thanks. Share this post Link to post Share on other sites
rwilson 128 #6 Posted September 4, 2010 TT that wouldnt be a chilton manual would it? My dad has one and we call it the "BIBLE". Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #7 Posted September 4, 2010 Nope - not Chilton. Pretty sure it's not a Haynes or Clymer either, but I remember it was like $30 - about 20-25 years ago. It was the only one I could find that had both Sundstrands hydros and Speedex tractors, so I snagged it. I'll dig it out tomorrow after work. Edit: OK - it just hit me. I'm pretty sure it's an Intertec manual. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,590 #8 Posted September 4, 2010 Butch, I hope you did not mess with the adjusting screw... That will change the pressures on the valve and it could cause serious damage to the hydro system. Share this post Link to post Share on other sites
bitten 134 #9 Posted September 4, 2010 You can also look at the Wheel Horse Hydraulic Lift Valve & Cylinder Repair Manual Part Number 810242R3. Forget were I got it from but it was on the net somewhere. Share this post Link to post Share on other sites
Retired Wrencher 6,056 #10 Posted September 4, 2010 :) how about my Wheel horse .com?? lot of stuff in there Share this post Link to post Share on other sites
Butch 194 #11 Posted September 4, 2010 Butch, I hope you did not mess with the adjusting screw... That will change the pressures on the valve and it could cause serious damage to the hydro system. Stevebo what is the adjusting screw? The screw inside that cap? If so I took it apart. That is the only screw I touched. When I decided to replace all 4 hoses I was gonna consider rebuilding the valve if it was rebuild-able. Then I decided against it. I just hope replacing all 4 hoses and rebuilding the cylinder took care of the leak. I never did see where the leak was coming from but one of the O-rings from the cylinders piston was no good. But the cylinder O-ring shouldn't be the leak I had. Share this post Link to post Share on other sites
Butch 194 #12 Posted September 4, 2010 Glad you caught this Stevebo. So do you know about adjusting them? Share this post Link to post Share on other sites
stevebo-(Moderator) 8,590 #13 Posted September 4, 2010 Butch, You may want TT to chime in here. I had the same issue on my 520 hydro valve leaking over the winter and Nylon/Coach gave me one he had that fit my machine. In my little experience with hydro flow you will need to put a hydro gauge on it and check it against the oem specs (maybe 700 psi??) You may have to bring it to a hydro shop and have them somehow preset it with a bench test?? I am sure that someone else will chime in?? I suggested TT since he gave me some good info on my post several months ago. Share this post Link to post Share on other sites
Butch 194 #14 Posted September 4, 2010 Steve is it the shoulder screw inside that cap that adjusts the pressure or another screw? In a service manual it mentions don't make any adjustments but I can't tell if they are referring to the shoulder screw or another screw. It does say Do Not Touch but to replace the O-ring you have to remove it. That's why I was wondering if it's the shoulder screw or maybe another screw on or in the valve. This sucks if it's the shoulder screw!!! Typical Butch luck!! Thanks for that heads up though! Share this post Link to post Share on other sites
Butch 194 #15 Posted September 4, 2010 You can also look at the Wheel Horse Hydraulic Lift Valve & Cylinder Repair Manual Part Number 810242R3. Forget were I got it from but it was on the net somewhere. Thanks Bitten. I did a Google search and that manual came up!! Share this post Link to post Share on other sites
Butch 194 #16 Posted September 4, 2010 When you look at the manual it looks like the pressure is set by the implement screw and not the shoulder screw. What do you think? I gotta be sure about this!! These hydraulics can be a real pain I see!! Maybe my next tractor will be an automatic tranny with manual lift!! http://natecrosby.com/andy/WHorse/whlifhyd.pdf Share this post Link to post Share on other sites
