wh79d160 52 #1 Posted September 3, 2010 :USA: Pulled the column out of my 79. Took it apart & the lower bearing cage is toasted & i could only find 4 of the 8 bearing balls that are supposed to be in it, The spring washer was gone also. Obviously some one has been in it before. The bearings are N/A from toro but I believe it is a fairly common ROSS column, Other than the crazy expensive guy on E-bay w/ the kits, does any one know where I can get parts for it? I also need the pinion stud that goes in the side, Toro has it still avaliable for $41.65 Thanks in advance. Share this post Link to post Share on other sites
ol550 831 #2 Posted September 3, 2010 Got mine from John Deere same as the old 200 series. The spring washer at the bottom was no longer avaliable. Mike Share this post Link to post Share on other sites
