Torino 15 #1 Posted September 3, 2010 '69 Electro 12hp kohler. Starter will not quit running even with the switch in the off position. Switch and solenoid less that a year old. :) Share this post Link to post Share on other sites
Save Old Iron 1,573 #2 Posted September 3, 2010 Disconnect the "small wire" from the starter solenoid. If the starter disengages, its a bad switch. If not, then the solenoid is toasted. Share this post Link to post Share on other sites
WNYPCRepair 1,924 #3 Posted April 30, 2018 On 9/3/2010 at 2:54 AM, Save Old Iron said: Disconnect the "small wire" from the starter solenoid. If the starter disengages, its a bad switch. If not, then the solenoid is toasted. Thank you sir. I just had the same issue on my 520-H. Ordering a switch. Before I figured out what that God awful noise was (it randomly kicked in while I was driving) I thought my engine had blown after 12 hours. Share this post Link to post Share on other sites
