stoneman 10 #1 Posted September 1, 2010 pulled the fuel line and cranked it over and the pump is working. removed the air filter and sprayed gas into the carb and it will start and run fine as long as i keep spraying. any suggestions? thanks . . .scott Share this post Link to post Share on other sites
jdog_kustoms 82 #2 Posted September 1, 2010 sounds like the carb needs cleaned and gone over or could be as easy as readjusting the needle screws Share this post Link to post Share on other sites
rmaynard 16,836 #3 Posted September 1, 2010 As Jordon said, I would suspect the carb. You may have something as simple as a stuck (closed) float valve. A good cleaning is always a good first step. Bob Share this post Link to post Share on other sites
Coadster32 793 #4 Posted September 1, 2010 I echo the "carb clean" idea. You could also just hang over the steering wheel and spray either as you go. :) Share this post Link to post Share on other sites
stoneman 10 #5 Posted September 1, 2010 Got it straightened out. You guys were 3 for 3. thanks. Share this post Link to post Share on other sites
