wheel horse man 56 #1 Posted August 31, 2010 (1) I would like to know what is the diffrence between a 8speed and a 6speed (2) Next what tractors have a 8 pinion 8speed in them. (i do know that 8pinion has a 1 1/8 axel) (3) does my B-80 8speed 1977 have and 8pinion in it any help would be great :wh: Share this post Link to post Share on other sites
rmaynard 17,421 #2 Posted August 31, 2010 Your B-80, if it has the stock transmission, has the 8 pinion differential. I guess any 8 speed could be considered a 6 speed if you don't count reverse. Wheel Horse called their 5060 a 6 speed even though it had 3 forward and reverse plus Hi/Lo. 8 pinion differentials were found in 5091, 103907, 103916 & 103918 transmissions. Bob Share this post Link to post Share on other sites
wheel horse man 56 #3 Posted September 1, 2010 my B-80 8-speed has a UniDrive 2988185 Pat# Is that a 8pinion and is a 8pinion that most srongest wheel horse trans out there Share this post Link to post Share on other sites
rmaynard 17,421 #4 Posted September 1, 2010 That's just the patent number. The model number should be 103907 for a 1977 B-80. That is an 8-pinion tranny. All Wheel Horse trannys are strong, but the 8-pinion seems to be the one coveted by pullers. Bob Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #5 Posted September 1, 2010 (1) I would like to know what is the diffrence between a 8speed and a 6speed The Wheel Horse marketing team. In order to make people think they were getting as much or more than what the competitors were offering, the marketing team counted hi & lo reverse as "speeds" beginning about 1973. I've "been inside" quite a few Uni-Drives and have seen everything from a broken input shaft to stripped or chipped gears, blown spider, ring, and axle gears, broken axles, etc. They are strong, but not indestructible - and yes, the 8 pinion differential is the strongest production differential offered by Wheel Horse. Share this post Link to post Share on other sites
wheel horse man 56 #6 Posted September 1, 2010 :) for the :) Share this post Link to post Share on other sites
