Coadster32 793 #1 Posted August 31, 2010 I am tearing into the K181 engine on the 854. I noticed that the Kohler manual says the cylider bore could be tapered .003 and be out of round by .003. Being a machinist, I think that's scrap, and can't see how the rings would seal. The motor is smoking, and plan on doing a valve job, and fully inspecting the cylinder as well. Has anyone used these tolerances as acceptable, and made good with a new set of rings? Share this post Link to post Share on other sites
W9JAB 156 #2 Posted August 31, 2010 As an "old motor builder" standard practice is for moving parts a .002 over size is normal, the oil would fill that gap. Now this was for the Older Harley motors that used a very heavy straight weight oil in an air cooled motor. With today's thinner oils I don't think it would be an acceptable range. Share this post Link to post Share on other sites
sorekiwi 761 #3 Posted September 1, 2010 The way I look at it is that the engineers at Kohler know a lot more about it than I do, so if they say its OK who am I to argue? And I also think that they would probably err on the conservative side when they publish specs - so I might take a chance if I'm close to the limit, but it'll be my own fault if it doesnt work. As for oils, Kohler specs a straight 30 wt oil for summer use, why would you want to run "todays thinner oils"? Share this post Link to post Share on other sites
VinsRJ 723 #4 Posted September 1, 2010 I'm with sorekiwi on this one..... there's been times when I just honed the cylinder and ran it with new rings, no problems what so ever. Straight 30 for K-serires IMO. Share this post Link to post Share on other sites
Coadster32 793 #5 Posted September 1, 2010 The way I look at it is that the engineers at Kohler know a lot more about it than I do Point well taken. I won't know what I got untill I open her up. I suppose the easy route would be a quick hone, and a new set of rings. (I still won't make parts that bad though) Share this post Link to post Share on other sites
buckrancher 2,694 #6 Posted September 1, 2010 sounds right too me chris. The cylinder should be bored straight piston is tapered .003 out of round and tapered is the edge of junk you must remember those tolerance's are the limit if it's much more than .001/.0015 I would be boring oversize if you have the motor apart Share this post Link to post Share on other sites
sorekiwi 761 #7 Posted September 2, 2010 Frickin Machinists!! Yes the bore has to be a certain size, and the piston has to be a certain size, and the rest is the clearance. In 46 years I would expect there to be a little wear in the bore! I'd be pretty happy to have just .002" and I'd be happy to put a set of rings in it! If I had someone bore a cylinder for me, I would expect it to be round and straight. But 46 years later I wouldnt be surprised if it was a little off... Share this post Link to post Share on other sites
Coadster32 793 #8 Posted September 2, 2010 Frickin Machinists!! Yeah I know, it's a curse. I tell myself that all the time when I do house framing work. :) Share this post Link to post Share on other sites
