wheelly 0 #1 Posted August 31, 2010 I got a 67 L157 lawn ranger last weekend and restoring it. came with a plow. Iknow the plow brackets bolt to the front of the frame. the problem not sure what i'm missing to raise the plow up and down. A few pics would be a lot of help. The plow is the same as pictured in the plow section. :) Share this post Link to post Share on other sites
littleredrider 409 #2 Posted August 31, 2010 I just got a plow for one of my rangers. The brackets that bolt to the side of the frame only go on with one set of holes. Some of the holes are used for the mower deck, not sure what the others are for, so the bracket will on bolt on with the right mounting holes. (Only 2 sets to choose from, not hard to find the right one ) I'll try to get some pics of it this afternoon. Share this post Link to post Share on other sites
pfrederi 19,471 #3 Posted August 31, 2010 Hope this helps you. My L107 can really move some snow, and she will go to work immediately unlike her Kohler brethren that have to warm themselves up.... Click for full size Share this post Link to post Share on other sites
wheelly 0 #4 Posted August 31, 2010 THANKS..help a bunch..I'm missing to 2 lever pieces from lift arm to plow. guess i got to find some parts. Just another WH mission. again :) Share this post Link to post Share on other sites
wheelly 0 #5 Posted August 31, 2010 I think I'm still not seeing the big picture or just plain dumb but there must be another part i'm not seeing cause what i see if i lower my lift are down my blade would go up. There has to be a pivot or jack shaft that i don't have. :) Share this post Link to post Share on other sites
Lane Ranger 11,702 #6 Posted August 31, 2010 I can send you some measurements on this piece if this will help you. The photo attached shows the two pieces for that attached to the Lawn Ranger lift handle and the bottom of the plow to angle it up and down. :) Share this post Link to post Share on other sites
wheelly 0 #7 Posted August 31, 2010 thanks for the pics. measurements would help. i can fab those pieces. Guess i better leave for work. Share this post Link to post Share on other sites
littleredrider 409 #8 Posted August 31, 2010 Plow is right outside in my truck if you still need some pics. I have the whole thing, and had it on, so I know it works.... :) Share this post Link to post Share on other sites
Lane Ranger 11,702 #9 Posted September 1, 2010 Some more photos and measurements for the Lawn Ranger snowplow lift pieces. Overall length of long piece is about Correction: 21 1/2 inches. length on the inside of the curve (until the curve starts) is: 18 1/2 inches. Holes on ends of the long piece are 2/8 inches and about 5/8 inches in from the ends and centered. All the steel plate is 1/4 inch thick and 1 1/4 inches wide. All the holes are 3/8 inches in size. Short piece with two studs and one hole on the short stud side is 6 1/4 long. Short stud is 1/2 long and is about 3/8 in round size. Note the short piece hole is NOT centered but more to one side of the piece. This is shown in photo one and three. Long stud is about 1 inch long and has a cotterkey /push pin hole in it to hold in place. Hole for cotterkey is more towards the outside. Top View of short and long pieces attached: I hope this helps you and others wanting to use the Lawn Ranger plow. Share this post Link to post Share on other sites
Lane Ranger 11,702 #10 Posted September 1, 2010 The link below is to some wheel horse snow attachments on wheelhorse.org. The last one listed is a four page manual for the Lawn Ranger snow blade that is listed as 6-3111 which was originally a BDR-385 snow/dozer blade. http://www.wheelhorse.org/manuals/Snow%20Attachments.pdf :) Share this post Link to post Share on other sites
pfrederi 19,471 #11 Posted September 1, 2010 THANKS..help a bunch..I'm missing to 2 lever pieces from lift arm to plow. guess i got to find some parts. Just another WH mission. again The Lawn Ranger Plow lift doesn't work like the big tractor plow lifts. The short link (with the welded on pins) locks to the tractor lift mechanism. When you pull back on the lift handle the short link is forced forward and transfers that movement to the longer bent link. As that is attached to the plow frame below its pivot points (the plates on the tractor frame) it works to raise the blade. This lifting movement is similar to the the Lift tube and flag used on snowblowers. Share this post Link to post Share on other sites
wheelly 0 #12 Posted September 1, 2010 thanks everyone. I printed this off. I got the blade sandblasted and primered this morning. Maybe this weekend and paint is cured i will be able to get the blade attatch and make my linkage's. again thanks. Share this post Link to post Share on other sites
William fox 1 #13 Posted September 23, 2015 Hey wheel horse owner ,I am looking for snow plow attachent if anybody knows where I can find one . I am onthe process of restorieing a 157 know for my grand son now Share this post Link to post Share on other sites
pfrederi 19,471 #14 Posted September 24, 2015 Hey wheel horse owner ,I am looking for snow plow attachent if anybody knows where I can find one . I am onthe process of restorieing a 157 know for my grand son now Probably have better response if you post this in the Wanted classified ad section Share this post Link to post Share on other sites
bowtieguy 334 #15 Posted September 25, 2015 If you happen to be west of the big ole Mississippi,,,,I've got 2 snow blades and brackets for your Lawn Ranger!!! Share this post Link to post Share on other sites
William fox 1 #16 Posted October 3, 2015 Hey wheel horse owner ,I am looking for snow plow attachent if anybody knows where I can find one . I am onthe process of restorieing a 157 know for my grand son now Share this post Link to post Share on other sites
