Trouty56 567 #1 Posted August 27, 2010 Got a C-160. What is the routing of the flexible cable housing for the rear lift cable?? I know it travels under the toolbox, between the hydro pump and tranny, but then I guess it ends up under the dust plate below the motion controls. Is the end at the toolbox butted tight against and what little extra hangs under the tractor?? Thanks in advance..... Share this post Link to post Share on other sites
besman 0 #2 Posted August 27, 2010 This is the only pic I have of my C-160 8sp with the cable coming out the back. I can snap a few other pics of it this evening if you want. Share this post Link to post Share on other sites
Trouty56 567 #3 Posted August 27, 2010 I guess I am more curious about the routing from the front. It is a C-160 Auto which might be worth mentioning...sorry. There is a dust plate under the motion control and it doesn't make sense for the cable housing to run on top of it. The cable that attaches to the bell crank wouldn't line up. When I place it under the plate it doesn't fit very well but it would line up OK it appears. It looks like there is a bit coming out from the toolbox on your setup. Thanks for the pic. Share this post Link to post Share on other sites
