wheel horse man 56 #1 Posted August 25, 2010 i need a web site that can help me buy parts for my H55D lauson for my 551 suburban or if some one has old new stock or some one that repreduces these parts thanks Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted August 25, 2010 http://www.wheelhorseforum.com/index.php?showtopic=4908 http://www.wheelhorseforum.com/index.php?...topic=12371&hl= There are quite a few more threads on this site, the above 2 just came to mind.. Share this post Link to post Share on other sites
wheel horse man 56 #3 Posted August 26, 2010 i all ready have the parts list i just want to see is i could get a new piston and rod and rings and wrist pin and a carb rebuild kit Share this post Link to post Share on other sites
VinsRJ 723 #4 Posted August 26, 2010 Have you tried Jacks Small Engines? They seem to have everything I've ever needed. Share this post Link to post Share on other sites
sorekiwi 761 #5 Posted August 26, 2010 If you have the parts list giving part numbers the dealers might be able to come up with some bits. The problem I had (a few years ago) was that the parts list wasnt on anyones computer (it was all on microfiche) so nobody seemed to be able to come up with numbers. I ended up using an H60 gasket set and rings. I suspect the H60 piston would work, but I havent compared them. Somewhere I have a number for the carb kit, which is available, look for one that has the main jet on the bottom. I;ll post the number when (if!!) I find it. Share this post Link to post Share on other sites
