kpthorsefan 34 #1 Posted August 22, 2010 Hi all, i need a bit of help, will GT14 tail lights fit a c141 with out drilling more holes? :) Share this post Link to post Share on other sites
Kelly 1,033 #2 Posted August 22, 2010 Not sure about GT lights, but I know marker lights over here made for semi's fit but you have to drill a hole in the back of the light to run the wire through as it don't line up with the fender hole, here they can be had for about $4 each, and are very very close to a match for the orig lights they came with. Share this post Link to post Share on other sites
Kelly 1,033 #3 Posted August 22, 2010 not the best picture but here are marker lights on a C series fender pan, it is the newer C with the tank under the fender they have two tail lights, or reflectors, most don't have lights. Share this post Link to post Share on other sites
kpthorsefan 34 #4 Posted August 22, 2010 Not sure about GT lights, but I know marker lights over here made for semi's fit but you have to drill a hole in the back of the light to run the wire through as it don't line up with the fender hole, here they can be had for about $4 each, and are very very close to a match for the orig lights they came with. Thanks for the info kelly and thats a nice looking tractor. Share this post Link to post Share on other sites
