DMESS 24 #26 Posted May 14, 2008 WHICH style bagger? Just might be interested! Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #27 Posted May 14, 2008 This one: Share this post Link to post Share on other sites
DMESS 24 #28 Posted May 14, 2008 TT, is it complete? Mounting brackets etc? maybe I can coax Eldon to bring it back when he comes up for the NAMA show? Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #29 Posted May 15, 2008 I'll have to dig it out and check, but it should all be there - including the mounting brackets. (The RH blade with the bolt-on "boosters" was gone long ago though.) Share this post Link to post Share on other sites
dgjks6 8 #30 Posted June 19, 2008 just wondering what the deck looks like now? Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,926 #31 Posted June 19, 2008 just wondering what the deck looks like now? That's a good question. I also would like to see the "after" pictures. :whistle: Share this post Link to post Share on other sites
Duff 207 #32 Posted June 19, 2008 just wondering what the deck looks like now? Not sure which post on this thread you're referring to, but if it's about the 37" SD we started out with, I'll take some photos tonight and post them! I was going to mount the deck on the tractor and test mow last night but when I was pulling it out of the shop I realized I never applied anything to the underside of the deck to protect the bare metal after my buddy sand blasted it. I was having too much fun prettying up the shiny side, so to speak. So in the interest of time I'm trying an old trick I've used with much success on my green tractors, the decks of which are both in awfully good shape (the STX is 12 years old and still solid). I slathered clean bar and chain oil on the metal and am letting it sit in the sun for the day. I'll wipe off any excess then hang it under the tractor, hopefully tonight, and see how this whole set-up works! I usually pressure wash and repeat this process in the fall when I put the decks away fror the season, then apply a light coat of oil again in the spring just before I start mowing. May not be an ideal solution, but it's cheap and has worked pretty darned well so far! I dom the same thing to my push mower and that deck at 8 years old looks brand new. I also hose off the underside of the decks after each mowing. Deereman :whistle: Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,926 #33 Posted June 19, 2008 I'm looking forward to the pictures. :whistle: Share this post Link to post Share on other sites
dgjks6 8 #34 Posted June 19, 2008 Yep, it is the 37 onch deck shown bare in the pictures above. I have the underside of my deck spotless right now. I may try the oil thing tonight Share this post Link to post Share on other sites
Duff 207 #35 Posted June 20, 2008 Yep, it is the 37 onch deck shown bare in the pictures above. I have the underside of my deck spotless right now. I may try the oil thing tonight If you've got some, I recommend bar and chain oil. The stuff is extra sticky and seems to last through several washinhgs while still protecting the metal. Here's how my deck came out: I've got the chute but just haven't put it on yet...... Cheers! Deereman :whistle: Share this post Link to post Share on other sites
dgjks6 8 #36 Posted June 20, 2008 thats a beaut - now I want to do that I leave the chute off mine - if I have it on it does not disperse the clippings as well and I have to rake. Without it on, no raking Share this post Link to post Share on other sites
Duff 207 #37 Posted June 20, 2008 thats a beaut - now I want to do that I leave the chute off mine - if I have it on it does not disperse the clippings as well and I have to rake. Without it on, no raking Thanks, Greg! Aahhh - I hadn't thought about the windrowing effect - good tip - also thanks! I had thought about leaving the chute off simply because I don't need something extra hanging out the side if I get distracted by one of the many [female ] joggers who go by my house and I happen to drift too close to one of the trees in my yard or my wife's flower beds ! Deereman :whistle: Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,926 #38 Posted June 20, 2008 The deck looks awesome. Nice. As for leaving the chute off, I have mine on, but I have tied up out of the way - mainly to get in and out of the shed door. :whistle: Share this post Link to post Share on other sites
Duff 207 #39 Posted June 21, 2008 Hi, folks! Got the deck mounted and took it for its first test mow this afternoon. I need to adjust the front-to-back level (to get the front 1/4" lower than the back), and the main lift linkage to get the deck bumpers up to touching the footrests when at full lift, but otherwise it was an awesome experience! Thanks for the advice and encouragement along the way! Now it's time to turn my attention to that belly-mounted grader blade I've been tinkering with..... Deereman :D Share this post Link to post Share on other sites
Rollerman 291 #40 Posted June 21, 2008 I have one I need to dig out & fix up for this fall. I plan on useing it with my PeCo lawn vac for leaves. I figure the 37" doesn't set out so far away from the tractor...with the collector from the vac on a 42" or 48" deck it makes things pretty wide. I figure that 37" would be a hot setup for it. Going to have to do some hammering though...it was on my dads 310 & not sure what he hit's when he mows...water valves...manholes.... :whistle: Share this post Link to post Share on other sites
Duff 207 #41 Posted June 25, 2008 The deck looks awesome. Nice. As for leaving the chute off, I have mine on, but I have tied up out of the way - mainly to get in and out of the shed door. Hi, T-MO! Have you got your chute hinged somehow? Mine direct-bolts to the deck. I'd dearly love to have the swing up feature if its available? Thanks! Deereman :whistle: Share this post Link to post Share on other sites
Stigian 1,235 #42 Posted June 25, 2008 Nice job on the cutting deck Deereman If you ever fancy a working holiday in the UK, the deck on my Raider could do with a lick of paint :WRS: Share this post Link to post Share on other sites
KyBlue 655 #43 Posted June 25, 2008 Turned out great!! Share this post Link to post Share on other sites
bustedglass 2 #44 Posted June 29, 2008 Hi Deereman, The deck turned out GREAT !!! As far as the hinge goes, I put a piano hinge on mine, so it would swing up, and over. Just my .02 cents ............. Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #45 Posted June 29, 2008 And guess what just showed up on ebay........ One of those fancy 6-sided P/N 111178 belts. (starting @ $15.00 ) SEE IT HERE! Share this post Link to post Share on other sites
HorseFixer 2,015 #47 Posted June 30, 2008 Nice Job Deereman Looks great! Duke Share this post Link to post Share on other sites
Duff 207 #48 Posted June 30, 2008 And guess what just showed up on ebay........ One of those fancy 6-sided P/N 111178 belts. (starting @ $15.00 ) Thanks, TT! Just made a bid.....never hurts to have a spare around just in case! Deereman :WRS: Share this post Link to post Share on other sites
Duff 207 #49 Posted June 30, 2008 Hi Deereman, The deck turned out GREAT !!! As far as the hinge goes, I put a piano hinge on mine, so it would swing up, and over. Just my .02 cents ............. Hi, Mike! Piano hinge- great idea! Time to do some more tinkerin' I reckon! Thanks! Deereman :whistle: Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #50 Posted June 30, 2008 That's what I was thinking...... now we have to make sure "DMESS" Dustin knows not to bid. :whistle: Share this post Link to post Share on other sites
