JUSS10 250 #1 Posted August 21, 2010 well i have been playing around with the idea of building a 3 point hitch setup for a round hood that utilizes the current lift hitch. well last night and this afternoon i started doing some cutting and welding on some scraps around the garage. i am in the process of building a sprayer so i built a frame to hold the tank. keep in mind this is a rough prototype but it works flawlessly. i am in the process of designing a finished piece that will attach right to the trans like the slot hitch does. pull the pin, pull the slot hitch, then put the lower links in and slide the hitch pin back in. that will eliminate the slop from the slot hitch. here are a few pictures Share this post Link to post Share on other sites
VinsRJ 723 #2 Posted August 21, 2010 Now that's just plain cool, you did great for prototype. :) Share this post Link to post Share on other sites
JUSS10 250 #3 Posted August 21, 2010 I'll probably build a finished one that looks something like this. i quick drew this up in rhino. 1 Share this post Link to post Share on other sites
buckeye 5 #4 Posted August 21, 2010 that's a nice lookin' setup. may have to copy that. :) Share this post Link to post Share on other sites
tranders 0 #5 Posted August 21, 2010 Looking forward to seeing the finished product. Great work. Share this post Link to post Share on other sites
ducky 1 #6 Posted August 21, 2010 looks great. i'd also like a copy of that for my 550. how much$$ for the fished product ? Share this post Link to post Share on other sites
JUSS10 250 #7 Posted August 21, 2010 honestly don't know yet how much it would cost. i would think less than $100 finished. i need to price out materials then decide if i cut it all myself or get it laser cut. school starts here in a week which means my play time is over :) Share this post Link to post Share on other sites
ducky 1 #8 Posted August 21, 2010 well im in no rush for it. but it wold be nice to have a carry-all / sprayer attachemet. i do like the the idea. well if u want to build a cople sign me up for one. Share this post Link to post Share on other sites
JUSS10 250 #9 Posted August 21, 2010 so you want a sprayer and the 3 point setup? i was just talking about about the 3 point setup being under $100. the sprayer actually isn't to bad either though. i can get the barrels for $5 the nozzles and all the fittings would be around $30, then i got a really nice pump for cheap but I've seen the pumps for around $45. Share this post Link to post Share on other sites
ducky 1 #10 Posted August 21, 2010 well i'd probly make a low presure waterer. but it hard to tell what the other ideas i or other will come up with for the three point hitch. Share this post Link to post Share on other sites
JUSS10 250 #11 Posted August 21, 2010 right on. will let you know what the cost comes out to after i get a finished part done :) Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #12 Posted August 22, 2010 It looks good but if I may ask a question? Are you planing on using that small cable to lift and lock it in the up position? You may find that is a weak point. Share this post Link to post Share on other sites
JUSS10 250 #13 Posted August 22, 2010 the cable is rated to 1200 lbs. i actually broke a clevis before i have broke the cable Share this post Link to post Share on other sites
JUSS10 250 #14 Posted August 22, 2010 got a little further on the sprayer today. got the plumbing in and built a mount for the pump. also did some looking at TSC and found a linkage that i think would work for a top link. i found a collar wit ha 3/8 ID that i can put into the eye at each end and weld it in place. should work pretty well. i think i will build legs under the sprayer frame so the hitch can be dropped and i can just back up to the sprayer and lock it in. Share this post Link to post Share on other sites
