dusted800 1 #1 Posted August 18, 2010 Picked up a 88 wheelhorse 518H with the onan motor. Motor turns over fine but didn't have any spark. I cranked it for 10 seconds or so and it started sparking but stopped almost immediately and now it doesn't have any spark again. I pulled the cover and the flywheel(to clean the grass from the mice) and expected to find the wires chewed but they weren't . actually the stator and flywheel looked very good. Does anyone know how to test the coil and stator. I put a jumper wire directly from the battery to the + side of the coil to eliminate any possible problems with the safety items that maybe on this machine. do these onans have any common problems? Any suggestions on what to check would be great? thanx. wnk. Share this post Link to post Share on other sites
W9JAB 156 #2 Posted August 18, 2010 ch you points, in the little can may be stuck or mucked up :) Share this post Link to post Share on other sites
dusted800 1 #3 Posted August 18, 2010 motor doesn't have points Share this post Link to post Share on other sites
racinfool40 203 #4 Posted August 18, 2010 had same problem jumped as you did with wire to positive side of coil would run 4 a few min. then stop. In my case was coil put new one on and has run fine since about a year ago. and the coil was 139.95 thru my local toro dealer Good luck!!!! and keep us posted I have a 518-h also so if yours is different we know what to look out for. :) Share this post Link to post Share on other sites
Buzz 502 #5 Posted August 18, 2010 I don't know squat about Onans but you can download an engine manual from Toro. Page 8.1 tells how to test for spark. Go to: https://lookup3.toro.com/request/request.cfm Put 31-18OE01 for model # and "none" for serial number. Good luck. Share this post Link to post Share on other sites
dusted800 1 #6 Posted August 18, 2010 thanx buzz, thats exactly what I was looking for wnk. Share this post Link to post Share on other sites
dusted800 1 #7 Posted August 19, 2010 went through the test procedures and found it had a bad coil, no continuity between spark plug wire holes. thanx for everyones help. wnk. Share this post Link to post Share on other sites
