Save Old Iron 1,571 #1 Posted August 17, 2010 Welcome to another session of SOI University a recognized institute of higher learning, experimentation, investigation and serious shenanigans are the norm for the day. An old friend called me up to help him work on his lawn tractor - how could I refuse. We tried to get his non wheel horse 11Hp tractor started the other day. I was rewarded with this - a top terminal starter solenoid with symptoms of a good click but no power to the starter. We substituted a good solenoid and the tractor worked fine. I put this one in my pocket and had something to take apart and play with over the rainy weekend. Around here, rain means something comes apart ... A quick trip to the drill press to drill off the heads of the rivets securing the metal frame / base to the housing gets us this far removal of the nuts holding the copper studs and the trigger lead and pressing the studs out from the housing label a few interesting items on the back side of the coil assembly a closer look at the spot welding of the negative coil lead to the grounded body of the solenoid coil closer inspection of the problem area of this solenoid - vaporized contactor studs and contactor disc one contactor stud was really blown away in the area touched by the contactor disc the edges of the studs are vaporized because the disc only touches the studs in a limited area - this tractor also sat for years and the engine had seized - and many attempts were made to start the engine before it was free to turn over. so I cleaned up the contactor studs rotated both studs 180 degrees in the housing to provide a fresh area for the disc to contact flipped the disc over in the plunger mechanism to provide a clean non-pitted surface for the studs to contact and reassembled the parts back to original a few small bolts to attach the bottom ground plate to the body and the solenoid is now fully functional again. So if you have that one off type solenoid or just have to keep stuff original at all costs - this may work out for you. For me, its just a cheap date on a rainy weekend. 6 Share this post Link to post Share on other sites
Coadster32 793 #2 Posted August 17, 2010 Cool! Thanks for doing this. Question though. I understand the spring returns the disc off the stud terminals disengaging the starter and battery stud. Can you explain how the coil "throws" the disc there in the first place? (The clicking noise I would assume to be the disc getting thrown to the studs.) Share this post Link to post Share on other sites
Kelly 1,033 #3 Posted August 17, 2010 I just a few weeks ago swapped a solenoid on a cousins tractor, was doing the same thing, before calling me he put a new bat. and starter on it thinking it was clicking it must be good, so after swapping in a new one, to show him what was wrong ground the rivets off and showed him the burnt contacts, he was bummed he spent $150 before and it was a $17 fix. Share this post Link to post Share on other sites
rmaynard 16,223 #4 Posted August 17, 2010 Coadster32. Not to step on the professors toes, but here is the answer to your question. The solenoid coil is an electro-magnet. The plunger attached to the disc, which goes into the hole in the middle of the coil is steel. When you apply 12 volts to the coil, the electro-magnet quickly pulls the plunger into the coil, thus making contact electrical contact with the studs, (and the clicking sound). When the 12 volts from the starter switch is released (after the engine starts), the spring pushes the disc and plunger back away from the coil and studs. Bob 2 Share this post Link to post Share on other sites
Save Old Iron 1,571 #5 Posted August 17, 2010 Class participation - doesn't get any better than this - and Bob is right on the money. I think I have a pic of the coil inside the housing of the solenoid. I'll post that later today. @ Kelly, that's why I hate guessing so much - once you start to truly understand how this stuff works, a whole new world opens up - a much less expensive, less painful, less frustrating world. In this case, there was $0 cost - Ok - maybe a few cents for 4/40 bolts and nuts to reseal the housing to the mounting bracket. So if your in the business of refurbishing low budget tractors, a few of these tricks can easily save you a few $$ in profit. 3 Share this post Link to post Share on other sites
300zx 7 #6 Posted August 17, 2010 Chuck, looks good. The Kohler relays are very similar, but the studs are on the side with square heads. They are just as easy to service, especially when you are in a hurry and don't want to run to get a new one. Has any one tried to repair the Onan starter relay? I have a candidate, but I was waiting on someone else to go first!! Share this post Link to post Share on other sites
VinsRJ 723 #7 Posted August 17, 2010 Very Cool! I'll need to file card this in the brain....... :) Share this post Link to post Share on other sites
racinfool40 203 #8 Posted August 18, 2010 :) love this site I learn something new everyday Thanks for the lesson and sharing !!!!! Share this post Link to post Share on other sites
horsefeathers 15 #9 Posted August 18, 2010 Save_Old_Iron, I love your collage of higher knowlage! You should publish one of those "tractors electrical" for dummys books! SOI University Rules! I'am a member of the Shade tree, back yard, grass roots Fix it for nothing with nothing! Use your McGiver skills club! Sometimes I think I'am in over my head! Then I look up at the sky at night! WOW there's a lot hanging over our heads! Grease the lightning and keep our Wheel Horses turning! Thanks for all your help! HORSEFEATHERS! Share this post Link to post Share on other sites
Save Old Iron 1,571 #10 Posted August 18, 2010 Coadster, here are a few pics of the coil windings inside the solenoid case. As was mentioned, the magnetic force is created within the coil by applying 12volts thru the ignition switch lug to the coil. The magnetic force then causes the solenoid plunger to move the copper contactor disk into the contactor lugs. There is your first big "click". When the coil de-energizes, the return spring smacks the plunger back down into the stops located in the steel base-plate - there's click #2. Enjoy 1 Share this post Link to post Share on other sites
rickv1957 73 #11 Posted August 18, 2010 Nice thread Chuck,great info! Rick Share this post Link to post Share on other sites
Coadster32 793 #12 Posted August 18, 2010 I get the mechanical part of it. (12v to coil, magnetism throws pin and disc, contact between studs, spring released after 12v). It seems obvious that the coil directs the magnetism in such a way that it throws the pin and disc to the plates. I guess that's the technical part I don't quite get. I do understand that when current flowsdown a wire, a magnetic field is created around a wire. Share this post Link to post Share on other sites
YNOT 0 #13 Posted August 20, 2010 To determine the direction of plunger travel, apply the right hand rule of motion. With right hand, Fingers indicate direction of winding, Thumb indicates direction of plunger travel. Tony Share this post Link to post Share on other sites
Save Old Iron 1,571 #14 Posted August 20, 2010 Thanks Tony, check out this website http://www.physics.sjsu.edu/becker/physics51/mag_field.htm especially Fig. 27.34 it describes how to determine the direction of the solenoid core will travel and mentions a torque effect that actually spins the plunger slightly while the plunger is moving. This would explain why the entire rim of the contactor disk is pitted. Every time the starter solenoid is engaged, the area on the contactor disk spins slightly, exposing a different area of the contactor disk to the contactor studs. It's starting to make sense. 2 Share this post Link to post Share on other sites
FarmerJim 5 #15 Posted August 21, 2010 Thanks Chuck! because of your valiant efforts I'm starting to understand a lot more about electrical parts on these old machines. Do I get extra credit for noticing the pictures on our classroom wall? HorseFeathers should be proud! :) Share this post Link to post Share on other sites
Coadster32 793 #16 Posted August 21, 2010 Ask and you shall receive. Thanks Chuck! :) Share this post Link to post Share on other sites
Save Old Iron 1,571 #17 Posted August 21, 2010 Do I get extra credit for noticing the pictures on our classroom wall? HorseFeathers should be proud! If you want to get your picture put up on SOI's "refrigerator" for all to admire, just say so. All worthy submissions will be put on the wall! 1 Share this post Link to post Share on other sites
horsefeathers 15 #18 Posted August 22, 2010 You got me.... Horsefeathers and Pink Floyd on the "refrigerator"At SOI University! Thats right, I'am on the "Dark side of the moon"! When it comes to electricity! (is there electric on the dark side?) SOI has a formula for that question! So there are unknown "gassers" in the university ERRRR...I mean... Unknown gasses in the universe!!!! I enjoy a good electrical storm it's relaxing!!! Remeber in an electrical storm don't run for the trees (there's squirrels up there!) Hide in a ditch and cover yer Azz or head! If ya' know wich is wich? HORSEFEATHERS! Great advice on how to get something started!!! Thanks Chuck!!! Share this post Link to post Share on other sites
Save Old Iron 1,571 #19 Posted August 22, 2010 Hide in a ditch and cover yer Azz or head! If ya' know wich is wich? HORSEFEATHERS! whichever you do your best thinking with always worked for me ! 1 Share this post Link to post Share on other sites
horsefeathers 15 #20 Posted August 22, 2010 When I have a perplexing question (most offten electrical) I find myself scratching my head and azz and I do forget which is which!!! I guess I do my best thinking when I don't think! Or I'am in the execuitive wash room!!! Gold key you know! I try not to think too much... Whats that smell? HORSEFATHERS! If I can get past the smell I have a new topic! Early starter /generators how do they work? can they run CW or CCW I rember something about polerizing a generator! Share this post Link to post Share on other sites
Save Old Iron 1,571 #21 Posted January 16, 2015 Vince, here is the link I was directing you to for a better understanding on starter solenoid (relay) internals Share this post Link to post Share on other sites
rick 252 #22 Posted January 19, 2015 Very good lesson for the "uninitiated"! We used to do the same thing with the old Mopar gear reduction starters, to get them going again, on the cheap so to speak. 2 Share this post Link to post Share on other sites
specialwheelhorse 174 #23 Posted February 6, 2015 Just reworked one and thanks a bunch now I'm ready for the next thirty years. I won't last that long !! Only snag ,took a little while to round up four little 4-40 bolts But I got enough for two more rebuilds for $ 1.36 Wooo Hooo !! Share this post Link to post Share on other sites
