Moparfanforever 897 #1 Posted August 16, 2010 Hi Guys , I have a 1972 ( i think ) Charger 10 with Hydro and hydraulic lift. I was moving it in the garage and the drive belt started making noise and i noticed it had flipped over on the drive pulley. After that happened , the back wheels wouldn't turn , even with the valve in tow position. Took the belt off , the Hydo pulley turns , still will not roll. I jack the back up and the wheels will turn while in the air ?? Something wrong in the pump ?? I bought this to restore when i retire next year because of the hydraulic lift , but not so sure now. I am thinking about trying to swap another whole pump/rearend assembly from another tractor. If i go this route , could i swap one from a 300 or 400 series tractor ?? If i get a hydro tractor with a manual lift , can i still plumb the hydraulic lift to it ?? Thanks , and hope this all makes sense !! Darrell Share this post Link to post Share on other sites
rickv1957 77 #2 Posted August 16, 2010 Did your parking brake set?,Rick Share this post Link to post Share on other sites
Moparfanforever 897 #3 Posted August 16, 2010 Boy , do i feel like a Goof !!! That was it !! But i do feel better !! Thanks Rick !!!! Share this post Link to post Share on other sites
rickv1957 77 #4 Posted August 16, 2010 You are lucky as lots of the parking brakes have been ground off over the years,Rick Share this post Link to post Share on other sites
