JUSS10 250 #1 Posted August 10, 2010 ok, well away this past weekend i did some picking at an auctioneer's house down in North Carolina while visiting my sister. well i came home with some parts and pieces to build a lawn sprayer (brand new flojet pump) and a load of cultivator shovels as well as some other old tractor parts and small engine parts all for $10. anyway, with the pump and shovels i want to build a sprayer and i have also been thinking of build a two row cultivator. before i build these for a sleeve hitch or attach-a-matic i was wondering if anyone has ever built a cat 0 3 point for a round hood. it would go on an 854. i figure the bottom two points could be on a frame that attaches in the sleeve hitch and a top link bracket that mounts where the seat spring bolts to the transmission. i guess my main question isn't if its possible but rather if i should build one to cat 0 specs or if thats to large. would an 854 be capable of cat 0 equipment (back blade, box blade, yard rake, etc) or if i should just build my own to work with my own custom implements. has anyone seen or built a setup that utilizes the sleeve hitch? i did a search on the forum but didn't find anything. i know i wont be able to apply downforce besides adding weight to the implements, i just think it would be cool to build and a nice base for custom implements. thoughts, comments? thanks Justin Share this post Link to post Share on other sites
WheelHorse_of_course 100 #2 Posted August 10, 2010 1) Be sure to check ALL of the settings in the search function - the defaults are not that useful 2) Search "Load Ranger". Among other cool stuff you will see Nick's 3 pt hitch. :thumbs: Share this post Link to post Share on other sites
fireman 1,022 #3 Posted August 10, 2010 Someone here on Redsquare has already put a 3 point on a round hood. I'll have to search to try and find the thread. Share this post Link to post Share on other sites
JUSS10 250 #4 Posted August 10, 2010 Nicks load ranger helps a lot. Thanks for the search key words Share this post Link to post Share on other sites
JUSS10 250 #5 Posted August 11, 2010 ok so i've been doing some more research looking at what else is out there on garden tractors. i think i got a pretty good idea but i have one question. what stops the 3 point equipment from swaying side to side? it looks like all the links have a ball at the end which i my mind would allow the implements to sway left to right? am i missing something? hope to get a rough computer model drawn up and will post what i come up with. thanks Justin Share this post Link to post Share on other sites
Matthew hurst 1 #6 Posted August 11, 2010 It will sway a little . Some big tractors have a bar to hold it for swaying The red arrow shows the bars. Share this post Link to post Share on other sites
JUSS10 250 #7 Posted August 11, 2010 thanks. i guess i need to allow enough movement to open the lower links and get the implement in. can anyone tell me what the value of B is on a category 0 implement or is that not a fixed thing? A appears to be 20" from what i found. Share this post Link to post Share on other sites
Matthew hurst 1 #8 Posted August 11, 2010 Do you mean how much it will madder to get the length right?? :thumbs: Share this post Link to post Share on other sites
wh500special 2,385 #9 Posted August 11, 2010 Rather than reinvent the wheel, you could perhaps adapt a Sears 3pt hitch to fit the rear of your tractor. Like this one: Sears 3pt from Wheel Horse Stan That way you'd be able to use appropriately-sized, readily-available Sears implements. They are smaller than cat-0. And the hitch mount to a plate like this: Mounting plate for Sears 3pt Just a suggestion... Steve Share this post Link to post Share on other sites
JUSS10 250 #10 Posted August 11, 2010 well for the price of that i could easily build my own. i'm just looking for some dimensions so i know where to start. i already have a plan in mind that i can build out of stuff around the shop. i think my uncle has an smaller cub cadet with a 3 point. maybe I'll just see how his works and build it off of his attachments. Share this post Link to post Share on other sites
DoctorHfuhruhurr 137 #11 Posted August 11, 2010 I have a Sears garden tractor with the manual 3 point hitch like the one mentioned in the previous post. If you want me to measure anything or take detailed photos let me know. Share this post Link to post Share on other sites
KC9KAS 4,746 #12 Posted August 12, 2010 Some 3 point hitches have chains that criss-cross to lessen the amount of sway, but still allow the bars to spread for attaching implements. Share this post Link to post Share on other sites
