cgambino 0 #1 Posted August 8, 2010 i am a newbie, thanks in advance for any advice have a 89 12hp 8 speed, kohler engine. once in a while and occuring more and more the clutch is engaging much lower than normal. after a few pushes it returns to normal. any idea of where is should start looking is appreciated. Thanks Chris Share this post Link to post Share on other sites
rickv1957 75 #2 Posted August 8, 2010 :thumbs: Rick what is condition of drive belt,Rick Share this post Link to post Share on other sites
Buzz 502 #3 Posted August 8, 2010 does it have one of those pneumatic cylinders to help the clutch? That's one of the signs when they start to go bad. Share this post Link to post Share on other sites
cgambino 0 #4 Posted August 8, 2010 thanks for the quick reply. the drive belt is original (20 years), some cracks, dont think its slipping. i will keep an eye on it to see if this occurs only when its hot. Chrsi Share this post Link to post Share on other sites
cgambino 0 #5 Posted August 8, 2010 Dont believe there is a pneumatic cylinders to help the clutch. Thanks Chris Share this post Link to post Share on other sites
MaineDad 87 #6 Posted August 8, 2010 Get down on the ground behind the tractor. On the left side of the axle, is there a spring the goes from the axle to the clutch pedal? Have some one push in the clutch and watch the process. You may have a worn spring or it's getting caught on something... Share this post Link to post Share on other sites
YNOT 0 #7 Posted August 9, 2010 Check clearance of idler pulley to side cover. Mine was doing the same thing, maybe the footrest got pushed in a little. When i took it apart i noticed that the pulley was slightly touching the cover. Under load made it worse. After adjustment everything was back to normal. Hope this helps Tony Share this post Link to post Share on other sites
Duff 206 #8 Posted August 9, 2010 Chris, is that a 312-8 machine? Along with what others have suggested, that pneumatic cylinder Buzz mentions is actually a damper to keep the clutch from engaging too quickly and causing wheelies. It will be located under the right fender (as you are sitting on the tractor) just rearward of the clutch assembly. While they normally fail by simply failing to provide the damping action, I suppose one could be hanging up causing erratic clutch release. Duff :thumbs: Share this post Link to post Share on other sites
