mailman 1 #1 Posted August 5, 2010 Ok, I don't weld. So, I need a way to lift my hitch to a height about 7 inches or so higher than standard height to accommodate my new log splitter. 2" ball A bolt-on solution would be easiest for me. Any suggestions would be greatly appreciated. Share this post Link to post Share on other sites
JoeMonag 1 #2 Posted August 6, 2010 Eric, there is a blacksmith in RI who makes a bolt on rig for about $ 50.00. I got one from his e-bay listing, they work great. You can go on e-bay and try wheel horse hitches. He also makes a rig taht fits on the front attach-o-matic. Good luck Joe in Norton,MA Share this post Link to post Share on other sites
wallfish 19,291 #3 Posted August 6, 2010 Maybe something like this might work. You'll just need to drill 4 holes into the 1/2" flat bar. cut the threaded rod and ream out the existing hitch's hole. You could probably use a smaller diameter threaded rod but I tend to build heavy. Uses the existing hitch to support the flat bar with the threaded rod so it won't rip out the 3/8 bolts. $.02 worth EDIT-- cut a piece of pipe to fit and use 1/2" threaded rod. Share this post Link to post Share on other sites
JoeMonag 1 #4 Posted August 6, 2010 Eric, if you scroll down to "Did some Horse Trading This Weekend" from Ken B. He has a picture of a C125, and it show the hitch adapter, you are lookinf for. Joe in Norton Share this post Link to post Share on other sites
rickv1957 77 #5 Posted August 6, 2010 A pretty easy item to make if you have the correct tools,Rick Share this post Link to post Share on other sites
